Question about Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan
Flickering lights I had two Hunter fans installed about a week ago, and both fans flicker when we shut the light off by the wireless remote wall switch. I have electricians coming out this week. The flickering is qutie irritating and we've resorted to shutting the light off by pulling the chain. I am a little bent because the wireless remote wall switches are not exactly cheap. I also had a Hampton Bay ceiling fan installed and I am having no problems with that fan. No flickering lights...it works perfectly.
    Problem Solver:
  • 5 Answers
Make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Posted on Jul 20, 2009
I just installed a 52"
yes this is because the dimer is giving the light less power.you just need to change the switch to a single switch then your dimer will work right all the time. good luck
Aug 12, 2011 | Hunter 52" Ceiling Fan With Light And...
We had the Hunter fan installed in April and have been very pleased with its performance. About a week ago whenever you turn on the fan light it flickers nonstop. Can you help me?
this is caused by the watt governor or the black box in fan to the lights. remove the watt governor and wire the lights directly. when removed, hook white wire to white wire, and black wire to red wire. black and red wires are always the hot wires. governor part number- 98480-02, have a good day !!
Jun 19, 2011 | Hunter (25417) Ceiling Fan
We have a 2 year old Hunter Fan Model # 23285 The fan works fine. Last week the lights began flickering. We changed bulbs, checked for loose wires, etc. The lights go on dim and continue to flicker. ...
if problems with lights flickering. remove governor inside for the lights, and wire lights direct. this should cure problem. ( black box or governor ). part # 98480-02-- have a good day !!
Jan 06, 2011 | Hunter Ceiling Fans Individual...
I am using spiral flouresent bulbs in my 4 light Hunter ceiling fan. The lights are always flickering. What is the problem? We do not have the remote installed
it has a watt governor on inside for the lights. remove this governor and wire the lights directly. this will fix problem. ( part #-- 98480-02 ).
Nov 17, 2010 | Hunter 52" Ceiling Fan With Light And...
Lights flicker on and off. Fan works fine
mcdevito75 here, If the wireing in your home / apartment is old and especially if you have an A/C unit or refrigerator on the same circuit as the celing fan lights may flicker with these other appliances going on. --------------- You can also check the wall switch that turns the fan lights on.
Jul 21, 2010 | Hunter 20551 52" Vernazza Ceiling Fan
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Wiring in Ceiling fan remote. Lights flicker
dip switches are not on the same signal?
Sep 07, 2008 | Hunter 27185 Remote Control
Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan Logo
1,239 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
