Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
I have a stackable Maytag. The water will not
I have a stackable Maytag. The water will not fill when lid is closed, but it will spin when closed? Any suggetions?
I had a similar problem I just fixed. There is a fuse inside that keeps the water from filling if it's blown. Might try changing that first.
Posted on Jul 19, 2009
  • ex-mechanic Apr 03, 2011
    Where is this fuse located? In the control panel at the front of the unit, or under the panel by the water hoses on the back of the unit?
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Maytag stackable top load wash maching - will fill with water but then nothing. It just stopped.??
Hi. Listen for an audible click as you just open and close the lid. You should hear a micro-switch. If you do not hear that click you most likely have a bad lid switch. A bad lid switch on a Maytag washer will still let it fill BUT, it will not agitate or spin.
If you hear a click then there are other things to that can cause the symptom that it would spin but not agitate.
Thanks for choosing FixYa,
Kelly
Aug 26, 2010 | Maytag WD16 Top Load Stacked Washer /...
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Won't run
sounds like your lidswitch.when you close lid you should hear or feel it click on and off.located on back side of lid in center.
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Feb 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
299 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
