Question about HP DeskJet 970cxi InkJet Printer
I am using nikon capture nx2 and a calibrated screen. the prints from my 970cxi on hp photo glossy paper come out cold with a blue cast over them. I am using output profile nikon srgb 4.0.0.0.3001 I have tried other profiles but with the same result. Short of creating a specific profile for my printer which I cannot do, what is the best profile to load?
5 Suggested Answers
SOURCE: Error 1168: Calibration Data not found
You have to put the file C:\WINDOWS\SYSTEM32\spool\drivers\color\spyder2express.icm into display properties (click right on the desktop, select "properties", parametres, click on button "advanced" and tab "color profiles"). I use a french OS, so words may be different.
Posted on Aug 16, 2007
  • 47 Answers
SOURCE: Background yellow on photo images. Profiles
you need to check into the settings you may want to set it to KMYB The color may adjust .
Posted on Nov 19, 2009
sys_admin
  • 829 Answers
SOURCE: How do I change the default color profile?
Instructions Download an icc profile above, then (in windows XP), go to display properties > settings tab > advanced > color management > add
Select the downloaded icc profile, set as default. You now need to reboot windows -
Posted on Jan 16, 2010
Salim Baig
  • 283 Answers
SOURCE: colors and photos do not
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Posted on Jul 07, 2011
Cannot transfer images from camera to computer using view nx2
Nikon split the functionality between two programs. ViewNX lets you catalog, view, and edit your images. Nikon Transfer is for transferring pictures from your camera. Current versions of Nikon software Nikon Knowledgebase
May 07, 2014 | Nikon Capture NX2 Photo Editing Software
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
My hp printer casts purple to black and white prints
Tried your settings with no luck. Also tried every canon profile listed to no avail.
These are my settings:
Color management:
Color handling: Photoshop manages colors
Source space: sRGB...2.1
Printer profile: Canon MP620 Series GL2/52G
Rendering: Perpectual
Media Type: Glossy Photo paper
Print quality: standard
Effects: borderless
Printer Preferences:
Color Intensity: manual-set-everything is 0-matching:none
I am using Kodak glossy paper and I am using that setting. I am printing a digital scrapbook page with color. I used black and white pictures in the page trying to get rid of the purple trees, so it shouldn't be printing any color at all in the photos, but the limbs are still purple.
Under color settings in PSE I have checked "optimize for printing".
I am off to the store to pick up another package of photo paper..maybe HP or Epson will be better (I think those are the other 2 choices in the store)
Will check back in after I try the other papers
Aftermarket car headlights
Jun 11, 2012 | Office Equipment & Supplies
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
DO RATE MY SOLUTION
Jul 07, 2011 | HP Designjet Z6100 InkJet Printer
My Deskjet 970cxi printer is now using too much ink (which does not dry) when printing photos on premium photo paper. the results on ordinary paper are much better. How can I rectify this Ian
When you give a photo print, the print quality will be high.
To adjust this go to Printer properties.
1) Go to control panel
2) Open Printers and Faxes.
3) Right Click on Printers.
4) Select Printer Properties.
5) Select Printing Preferences, and choose quality of photo print to medium
Dec 03, 2010 | HP DeskJet 970cxi InkJet Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Nikon Capture NX will not open black and white jpegs
Nikon Capture when initially installed you have to tell it what types of files to open.... IT has 3 tick boxes for NEF (Nikon Raw Files), TIFF, & JPEg, you actually have to tell it which types you want NX to open. The easiest way to fix the problem maybe to reinstall the program and reset the file association as you install it. Hope this may  help.
Jul 26, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
HP 6940 rejects 8.5" X 11" glossy photo paper for printing
Is it a front feed and then the output is also goes out to the front? Coz if your glossy paper is to tough that it will not bend easily, this is what you get. Why not try to use a thin and more flexing photo paper if the outcome will be the same.
Usually when using thick paper the most desirable printer should be a top feed-front output with almost less than 90 degree bend.
Apr 24, 2009 | HP Deskjet 6940 InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
