Question about Nikon Coolpix 4500 Digital Camera
Sytem error Unfortunately the camera does not start, when it is switched on. First it is crackling an then I can read "system error" on the display. Thank you for your assistance. Engelbert
  • 1 more comment
  • velyn Jan 30, 2008
    After turning on it makes clicking noise for a bit, then changes to a loud hum with the egg timer on the screen, and then changes to a system error message until it times out. Tried removing battery a few times and putting in the original memory but no difference.
  • Anonymous Feb 02, 2008
    Affter switching it on the screen displays sytem error until it is off.
  • trickybob52 Feb 23, 2008
    After turning on it makes clicking noise for a bit, then won't focus properly then shuts off...all in all something is not right!! Help! any advice is appreciated. I have made it to the re-set all function and that did not seem to make a difference.
    Thanks, Bob
  • 3 Answers
My first cooplix did this. I sent it to Nikon and they fixed it for $120.00. worth it
Posted on Jan 26, 2008
When starting up the lens comes out the camera beeps, the lens moves partially back, the display says date and time has been reset and then the screen goes blank/ camera switches off with lens stuck...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 15, 2011 | Kodak EASYSHARE M1063 Digital Camera
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
Lens error displayed in the left corner of the LCD. The objecting does not retract...no mechanical damage has been applied. Changing the batteries did not help.
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
Oct 30, 2010 | Canon PowerShot SX20 IS Digital Camera
Canon Ixus 130 gives message "Lens error Will shut down automatically Restart camera"
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 31, 2010 | Cameras
'Lens error please restart the camera' msg displaying
Jul 28, 2010 | Canon PowerShot A420 Digital Camera
When I turn on the camera it beeps and an error that reads lens error, restart camera appears and turns off. How do I fix this problem?
Hello
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Mar 31, 2010 | Canon PowerShot SD600 Digital Camera
Canon camera when turned on, lens will not
Hi
What you are seeing is a generic error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Apr 04, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Sytem doesnt boot up
Make sure that the display connector is well connected to the computer. Also, look behind if the switch in the back of the computer is on.
Aug 27, 2008 | Intel D845GVSR Motherboard
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
79 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
