Question about Sony KDS-R50XBR1 50" HDTV
Power light flashed red 4 times then repeats no pic,new bulb/fan!
I have a kds-r50xbr1. replaced lamp 3 months ago and again 2 days ago. tv wont turn on at all. power light flashes green the BLINKS RED 4 TIMES. then REPEATS. So if it's not the bulb or the fan what could it be? Please help !!
    Problem Solver:
  • 5 Answers
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Posted on Sep 09, 2009
Sony KDS-R50XBR1 /(2005) Red stand-by light blinks 4 times.Tried new bulb (Philips) 1 week ago ,same problem as before .Whole new light engine replaced two yrs ago by sony.What happens is it will turn off...
The error code of 4 blinks indicate a fan problem.the fan is slowing or internitantly stoping. the fan is stallling. or the fans not getting power. Always rember anything that moves will eventally stop. this fan is on all the time. also there more than one fan. Listen closely to hear the fan. The fan is not difficult or exspensive repair.
Mar 04, 2011 | Sony KDS-R50XBR1 50" HDTV
The lamp LED blinks 4 times and repeats, I replaced the lamp but the lamp led is still blinking 4 times and repeats and I have no picture
4 times blinking light indicates problem with exhaust fan in KDS-R50XBR1 and possible causes are as follows:
-Fan 1-4 power is not supplied. (ASU board)
-Fan connector is not attached securely.
-Fan caught wires or harnesses.
Please check exhaust fan in tv, it is located at lower right of tv looking at rear of tv.
Thanks.
Feb 04, 2011 | Sony KDS-R50XBR1 50" HDTV
I have KDS-50A2000 Sony SXRD Projection TV. Serial #9028985. It was working fine then a few days ago I went to turn it on and the red power light was blinking 4 times and repeat... I then opened the lamp...
hello, this can cause the red power light to flash 3 time also if the lamp cover is not fitted securely this can also cause the light to flash 3 times 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped hope it helps
regards
shaun
Jan 03, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
Power Light Flashes 4 times on my KDS-A2000
Check the cooling fan directly behind the bulb. mine fan is going out. im having the same issue with the light blinking. when i get the fan on. the tv stays on until the fan stops, then the tv turns off.
Jul 14, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
My sony sxrd projection tv wont turn on
From what I've been able to find, the problem is the fan that cools the bulb is not starting when you turn the tv on. Blow on it to get it going or clean with compressed air. The fan could be clogged up with lint etc. It's on the rear left of the tv.
Jan 05, 2009 | Televison & Video
TV will not power on 4 red blinks
I found the following suggestion on avsforum.com and it worked perfectly (going through the lamp door).
Nate
Quote: Originally Posted by Civicsixxx After some digging around I found that four blinks means there's a problem with a fan. I took the back cover off, used a screw driver to manually spin the fan near the lamp a few revolutions, plugged it back in and it powered right up! I guess it was just stuck or something. I'm a longtime lurker not much of a poster, but this happened to me to yesterday. I used civicsixxx's advice and this works. However you don't have to take anything apart. All I did was take out the lamp then put your hand in carefully to the right and you'l feel the fan just give it a spin and plug back in the light and the TV your good to go. Hope this helps.
Dec 12, 2007 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 50" HDTV Logo
649 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
