Question about Asko T721 Electric Dryer
Dryer wont turn on
I set the dryer to dry. Ran for less than 5 minutes and then it shut off. i fiddled with the breaker.....nothing. pulled the dryer out from the wall and made sure dryer was plugged in...was. So now i dont know what to go. please help! Dryer was working great.  Went to use it this morning, and the machine starts but stops as soon as I release the power button.  The manual says this is the overheating protection activating.  But the dryer sat unused overnight and it is still ice cold.  I clean the filter after each load.  I've only used the machine about 10 times.  I even checked the condenser and it, too, was clean.
  • Anonymous Nov 20, 2007
    Dryer wont heat. No one seems to have answer...
    Sergeant:
  • 351 Answers
The dryer has an overfill cutout if you start and hold in the start button you should hear the pump come on,and pump the water out. then the dryer will start.if it happens again you may have a blockage in the black drain hose take the top panel off and blow down it,or the pump itself could be faulty.(if the dryer is sitting on the floor you have to drain the water into the drawer, if its mounted ontop of a washing machine you can connect the long bkack hose to the sink.
Posted on Mar 02, 2008
Countdown timer not working
Good Afternoon Friend,
I understand that the timer on your Electrolux dryer, model#EIMED55IIW, is not advancing to show you how much time is left on the dry cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Restore power and restart your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 18, 2014 | Electrolux EIMED55IIW 8-0 cu- ft- Electric...
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
My kenmore dryer runs for 5 minutes and shuts off. I have replaced the door switch and ran the dryer with the vent hose detached. Still not working
Try this: Find the sensing bars and clean em with 409 or windex. They may be coated with stuff from dryer sheets. This builds up a moisture barrier. The machine does not FEEL the wetness from the clothes and assumes they are dry.So it shuts down after 5 minutes. Let me know.
Apr 21, 2011 | Dryers
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Why would an electric dryer trip the breaker when the dryer vent is disconnected from the duct work but not when it is connected? The dryer was taking sometimes 3 cycles to dry heavy loads.The duct work...
perhaps a safety feature to keep any burning lint from setting your house on fire also check the vent where it comes through the ouside wall of your house they sometimes get clogged with lint and the escaping air cannot vent properly and backs up ,if it is to warm it may tell your dryer sensor clothes are dry when not.I also find an xtra spin or 2 just spins ,not rinses .in washer extracts a lot more moisture out of clothes and they dry even faster
Dec 18, 2009 | Whirlpool GEW9250 Electric Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Dryer wont turn on
This is usually a symptom of a thermal fuse that has blown. A blown thermal fuse is a symptom of other problems (usually). That is to say that they generally blow for a reason. The most common cause is a dirty dryer and/or clogged vent duct. If it's been a while since you've cleaned your dryer and/or the vent duct, you might want to do so BEFORE you replace a thermal fuse. Or, the problem will persist. If your heating element is in the rear of the dryer, the thermal fuse will be located on the blower fan housing on the left hand side of the dryer. It is white in color. If the heating element is located inside the dryer under the drum, the thermal fuse will be located on the blower fan housing right under the drum in the front of the dryer. The fuse should read a short. If it does not, you need to replace it. It is not resettable. Let me know if you have any further questions. I hope this helps you.
Sep 14, 2007 | Whirlpool LER5636P Electric Dryer
Asko T721 Electric Dryer Logo
241 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
