Question about Garden
Engine running--when i engage parking brake it creeps forward how do I adjust
    Problem Solver:
  • 13 Answers
Your brake pads are probably spent or you need to adjust them....usualy behind the rear passanger tire...lol
turn the nut clockwise justa half turn...put the tire on and try again...this prosses is very painstaking because most of these machines its hard getting to this nut with the tire on
Posted on Jul 21, 2009
How do I adjust the parking brake on a 1988 Suburban?
First, adjust the brakes manually. The cable that runs to the rear end has an adjustment near the frame on the drivers side.
Oct 21, 2014 | 1988 Chevrolet Suburban
5 pseed manual / creeps forward on incline
OK I did see a couple of other suggestions but unless I read your question wrong your vehicle is not running when this is happening and right away i thought of two basic things when parking on a grade. They are first thing is when either parking up hill or down hill you always turn your wheels towards the curb and second you should always use the parking brake even though many people call it the emergency brake it really the vehicles parking brake when you have a ma
Apr 12, 2014 | 2005 Toyota ECHO
Car moves ofline when driving
the automatic transmission creeps? is that it?
that means the (brakes are dead) or the engine RPM is too fast.
if engine is cold (was it) the RPM can be and will be very high and will creep. so is it cold, the engine , and how cold, was it at time of creep
and what was the engine RPM.
or does e ofline mean off line or really means stalls.
as in, my engine when off line, like printer. or ?
wild guess there.
this is simple, all A./T have a clutch that has a stall speed
if you exceed that, RPM it does creep, that is how the a/T fluid clutch works. That is why say , when you idle a 800 RPM it dont creep
then you advance the throttle (engine rpm rises) there is a point
that car starts to move, this is the stall speed, threshold.
all normal.
this is why the operators guide has you start the engine brakes on
and trans in park then while holding the brake , you shift to drive
and prevent creeping,,,,,
Aug 07, 2013 | 1996 Jeep Grand Cherokee
I'm replacing my rear brake shoes on my 2001 chevy venture,i've assembled new parts and what has been happening is when i push on the brake pedal the adjuster actuator and actuator spring keep popping off...
Parking brake lever on leading shoe (end of retractor spring in its hole on the leading shoe). Make sure the the adjuster screw assembly is engaged properly with the leading shoe (also, engaged with the parking brake lever). Adjuster actuator installed on the trailing shoe (also, engaged with the adjuster screw assembly). After inserting the retractor spring in its hole on the trailing shoe, insert actuator spring in its hole (just below wheel cylinder) in leading shoe and stretch across and connect it to the adjuster actuator. Adjust star wheel to get shoes close to drum. Reinstall drum (shoes close with no rub). Reinstall wheel. Push brake pedal for final adjustment. Test forward. Test Backwards. If everything is in the correct place, nothing should pop off. I hope you have a before picture. Haynes manual has good pictures. I own a 2002 Pontiac Montana, but a family member has taken it out of town. My info is from the Haynes manual. I replaced the brake shoes a couple years ago.
Feb 20, 2011 | 2001 Chevrolet Venture
Could frozen e brakes cause car not to go forward, car moves easy in reverse
No. An emergency brake on the 86 camaro engages the pads against the rotor and the vehicle would not move either in reverse or forward. It sounds like you have a gear problem in the transmission that could be related to either solenoid or actual gear wear. Assuming the vehicle is being MOVED as you say while the engine is running.. thus providing the energy to move it.. Going in reverse has the solenoid engaged one way, drive the other way. Solenoid sounds damaged at this point. Unfortunately this probably will require a transmission rebuild.
Jun 06, 2010 | 1986 Chevrolet Camaro
Starting problem - 1999 Dodge Neon
ask the car mechanic expert
Oct 29, 2009 | 1999 Dodge Neon
1997 ford explorer rolls/creeps forward while in park
linkage is off, not starting in park, neutral safety switch maybe bad
Nov 26, 2008 | 1997 Ford Explorer AWD
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
