Question about HP Pavilion zd8000 Notebook
Power outlet when i unplug my laptop ... it hibernates ... when it turns on it says i needed to change power outlet ... how do i do this
  • 55 Answers
Check the energy options on control panel othewise you gonna need a new battery
Posted on Nov 19, 2007
Sony vaio laptop shutting down while plugged in
If it's left on for a period of time, specified by the power settings, it will dim the display, Hibernate, Sleep, etc. In the Control Panel, Power settings, Advanced Power setting , Change to High Preformance, adjust Hibernate and Sleep to Never, adjust advanced power setting to your specs. Shut down and unplug laptop , remove battery, when not in use, if you use on AC most of the time remove battery.
Jan 05, 2013 | Computers & Internet
Hp pavilion ze1115 stuck on hibernating..
Open Control Panel, Power, power settings, change power settings to high performance, Disable Hibernation, sleep. When your laptop is not in use shut it down and unplug. It will last longer and a boot everyday will reset the laptop.
Dec 17, 2012 | HP Pavilion ze1115 Notebook
Stuck in hibernation and wont power on
Pull the plug, remove battery, boot normally, change Power setting to High Performance, disable Sleep and Hibernation in Advanced Power settings. Shut down and unplug your laptop when not in use.
Dec 15, 2012 | Acer Aspire One PC Notebook
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
My computer won't wake up after going into
HI, i suggest you unplugged your system from the AC outlet and leave for sometime to rest, power it on back after few minutes and put on your system.
Doing this will help wake your system up from hibernation.
I wish you best of luck.
Jan 07, 2010 | IBM ThinkPad R40 2722 Notebook
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Laptop HP Pavilion dv6000 I have the problem. Power button wont work. Can start PC through QuickPlay button but when I try to go to Windows, PC hibernates.
i have had this problem before, and you can take off the strip above the keyboard and check the wire didnt come unsoldered or unplugged, but in most cases, it has to be replaced. if you can turn it on, i would reccomend just starting it that way.
Sep 01, 2009 | Computers & Internet
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
V5000 won't turn on now from hibernation mode
you might need to check your ac adapter and power outlet first before blaming your motherboard.
you go to hibernate mode because the battery is low. the battery is low because you ac adapter isnot supplying power to battery.
May 04, 2008 | Computers & Internet
you have to start doing a test on secuences first you have to make sure the power from the outlet to the end the cable it has 120 v ac if there is power you have to open the case to check the power suply output to the motherboard there is a power suply testers you can get that on fry'z electronics store i think thats where your problem is located power suply after you do this test post it back to see if does not fix the problem if does fix it leave your feedback
Jan 01, 2008 | Computers & Internet
HP Pavilion zd8000 Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
