Question about Nikon D80 Digital Camera
A black spot keeps appearing in my photos nikon D80
  • 813 Answers
It seems that there is some dust particle on the sensor. Try cleaning the sensor as per the instructions in the manual and then check. In case the spot still appears, then the CMOS sensor might be damaged / burned out and you will need to replace it.
Posted on Jul 19, 2009
Black spot on the picture
Hi cutesaying, if it is on all you photos in the same location it is one of two things, worse case is a bad sensor location (unlikely), most likely is there is crud on the sensor. You can perform a sensor cleaning if you fee up to it with specialized tools. Search the web for sensor cleaners there are many. Changing our lens is the most likely way dirt, and the like, gets on the camera sensor.
Jun 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
My nikon camera keep got error and dont have the
You have not provided enough information, what is the error read? If it shows ERR then: The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Mar 24, 2010 | Nikon D80 Digital Camera with 18-135mm...
Hi, My Nikon D80 is now kaing over exposed
This can happen if you have ISO control set to Auto and have spot metering selected, especially if it's set to spot shadow or spot highlight. Over exposure probably means it's set to spot shadow metering.
With spot metering the camera measures exposure from just a very small point in the scene, and so slight camera movements will cause the metering spot to wander onto different exposure settings very easily. If the camera is either set to use restricted apertures or shutter speeds due to program or lens limitations then it will compensate by adjusting the ISO settings instead
Never use auto ISO, just choose what you need for the conditions rather than using the camera's best (& usually poor) guess. Alsonever use spot metering unless you know why you're using it. The default multi-pattern metering is extremely accurate for most situations.
Please check the camera settings based on what I've said, if it fixes your problem then please rate my answer. If not then please add further details of which lenses and camera settings you're using and I'll try to help you further.
Oct 31, 2009 | Cameras
I want to know what setting to put my Nikon D80 on
keep the camera in manual mode and increase ISO more than 800 and shutter speed should be low , for black &white picture go setup in pencil mark & go to black&white option
Sep 06, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 LCD screen
Hello cherdh,
To disable those blinking spots, just press the up or down cursor keys at the back of the camera while in playback mode. You will get three different views. One shows the EXIF data (Image data) as an over lay on your photograph. Press the button again to go to histogram mode, with graphs. Press it again to go to a mode where some image data is on the bottom of the display with no blinkies on the image.
Those blinking black spots are called highlights in a photograph. They indicate the areas where your photograph is over-exposed, i.e. where there is too much light and the colours are washed out. It can be a good tool to get a good exposure. Keep clicking with different settings till you get an exposure without those blinking spots.
I hope this helps.
Satdeep
May 27, 2008 | Nikon D80 Digital Camera with 18-200mm...
Nikon d80
It might be caused by some dirt on your lens (either front or rear element) but is more likely to be dust on the cameras sensor.
There are a couple of sample images of what this looks like here and here.
Dust spots typically have a softish edge to them and affect more than 1 pixel. (if it is just the 1 pixel affected, which a very sharp edge, this could be a defective sensor).
Following the instructions in the manual for cleaning the sensor. Avoid touching the sensor (unless it is with a specialist sensor cleaning brush) and avoid cans of compressed air; use a hand-blower brush instead.
Matt
Mar 03, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 black spot center of photos
For D80, go to setup menu, select Mirror lock-up so we can see and access the sensor!
Sep 25, 2007 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera Logo
115 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
