Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
No ice My ice maker quit, i removed the cover and found the motor is ont turning. The fues in line is ok i replaced the unit and still no ice, any ideas. Thanks Bill
  • 2 more comments
  • vettsrfun Jul 19, 2009
    I checked the control valves in the rear and the resistance is 266 on one and 196 on the other. The model number is mzd2669kes thanks Bill
    Thank you for the info i just filled the ice maker with water and i will look at the fill tube. This info has been very helpful. Thanks again Bill
    I filled the ice maker with water and it is now frozen.But it will not cycle through. The ice maker is a new unit. Thanks for any more ideas. Bill
  • vettsrfun Jul 22, 2009
    Thank you very much for the info! I had to have a repair man come out and check out this problem. I was on the right track in replacing the ice maker, but the new ice maker was bad out of the box. I had him install another new one, and now we have ice again. So once again thank you. Bill..
  • Maytag Master
  • 4,655 Answers
You need to test the dual water control valve on rear of refrigerator with and ohm meter. Disconnect both sides from the power connections at the control valves. Test each coil with an ohm meter. You should get the same or close to the same reading on both coils. Let me know what your model number is and I will be able to tell you the part numbers, Thanks, Sea Breeze
Posted on Jul 19, 2009
  • 3 more comments
  • John Tripp
    John Tripp Jul 19, 2009
  • John Tripp
    OK now test the ice maker with tap water and let me know if the ice maker cycles after the water freezes. The water control valve may be the problem, but some use 120 volts to come on and others do not. Need to look in the back of freezer too to see that the water has not frozen the fill tube shut. The readings on the coils are about 1/3 different and they should be almost exactly the same because they are the same coil just different functions. If not it could be the internal thermostat in the ice maker. The part number for the water control valve is 67004098
    Thanks, For the rate, Sea Breeze
  • John Tripp
    Note if ice maker works by filling with tap water and dumps the ice then we know the water control valve is defective.
  • John Tripp
    John Tripp Jul 21, 2009
    I see you answered a couple days ago. I have had problems with getting notice that you or anyone made a comment. The new ice maker has a thermostat inside it. When it senses that the water is frozen then it should begin its cycle of heating the element below the ice cubes for a few moments and the the element turns off and the ice maker starts its turn to dump. After it dumps it returns back to the fill location and because the thermostat is not freezing like before the ice maker tells the water control valve to come on long enough to fill the ice maker and begin again this cycle. Something is wrong with the ice maker or the power supply to it. Sea Breeze
    appliancepartsse@yahoo.com
  • John Tripp
    John Tripp Jul 22, 2009
    Thank You Bill, This is the first comment I have received from Fixya in more that a month. I would have had the answer earlier if the problem with their server had been corrected sooner. I was having to go to every solution and look to see if someone made a comment. Anyway you are fixed and that is good! Thanks, Sea Breeze
  • Maytag Master
  • 1,606 Answers
Pour about 1/2 cup into icemaker and if it dumps , water valve is the problem . If not , and you already put in a new icemaker , then make sure the coils behind refrig are clean and the motor which cools the compressor is working . An icemaker has to be at least 5 degrees to operate .
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Ice Maker quit, everything started to thaw out.
Good day,
Limited information. The ice maker will go into auto lockout if the freezer goes above 14 degrees.
Motors make noise.
There is a fan motor behind the back wall, of the freezer compartment. If the machine is turned on, it should run, and you should be able to hear it.
If not, remove the rear panel and inspect.
The second fan motor, is located in the back rear of the machine, behind the rear cover, it should be running as well.
If both are running O.K. then it is in the compressor itself.
A pricey problem, if it's the compressor. Should be checked by a qualified tech.
P.S. If you feel it is a compressor problem, and the unit is less than 5 years of age, then contact your selling dealer. It would be under warranty.
Thank you for using FixYa
Jan 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
My ice maker is not dumping the ice it just freezes and stays in there help
You need to replace the ice maker . It is a lot less time consuming to replace the ice maker , than to try and repair it . But , if you want to try , you have a bad thermostat , or broken gear . If the gear type , pull the cover off the ice maker , and you will see the motor running ( small gear ) , but not turning the large gear . In this case , replacing the large gear , would be the best thing , instead of replacing the whole ice maker .
Nov 21, 2009 | Admiral Refrigerators
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker won't quit dispensing ice cubes don't have ice skates!
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repair
Dec 11, 2008 | Amana Refrigerators
BI-95 ULINE
raritan eng/whirlpool ice maker assembly
Jun 20, 2008 | U-Line Icemaker
Ice Maker
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Feb 13, 2008 | GE GSS25LGM Side by Side Refrigerator
U-Line undercounter frost free ice maker refrigerator
All units made today have defrost timers to clear ice from the evaporator. Some of the ice sublimates...turns directly into humidity in the air in the box. It re-condenses in the ice tray area. It is possible that nothing is wrong other than excessive opening of the bin area or the defrost timer is running slow and staying on too long. You may also be consuming the ice too slowly. Can you either change the amount of ice in the bin by adding something to simulate part of the ice content or shut off ice production against low demand?
Dec 18, 2007 | U-Line Icemaker
Icemaker does not work
check the water hose. water supply to ice maker
Sep 11, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
281 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
