Air bag light on
You have a sliding contact behind the steering wheel (called a clock spring). It is probably bad & needs replacing. Need to remove steering wheel for access. Usually there is a code set that says whether it's the driver side air badg or passenger side air bag that's the issue.
Somtimes, you can check it yourself by reading the number of flashes once you enter self test. Read owner manual or call dealer service dept and ask for self test procedure.
For a Ford, you turn key to "on" and then press the door dome lamp switch 7 times in 10 seconds and then read the codes. Not sure about Chrysler.
