Question about Acer Aspire 5600 Series 5630-6951 Laptop
In CD helper is present but failed to start
Have taken the Drive out to make sure it was on Master, reset the nero burn rights. What els can I do
I CAN`T BURN DVD WITH MY NERO BECAUSE IT TELLS ME THAT:ERROR TO HL-DT-ST DVDRAMGSA T50N ATA Devise.What can i do?
Hi marymichael2,
I see that you are having issues burning using Nero.
First check if the setting of Nero is correct for the DVD drive open Nero then go to Extras click on Get system info for Nero to detect the system devices and windows info for proper compatibility and Burning Detection of the DVD drive.
If the error states that there is something wrong with your DVD driver then you can check to see if resetting your DVD drive can fix the issue you reset you DVD drive by going to the registry editor.
regardless of what OS you have the steps are the same.
  • Click on Start then Click all programs look for Accessories, then look for CMD or Command Prompt then click it to open the registry editor Tool.
  • Once you have the Registry Editor on the left hand side window look for HKEY LOCAL MACHINE click on the arrow on the left side of the Folder to show the submenu,
  • Then click on the arrow on the left of System
  • Then click on the arrow of CurrentControlSet
  • Then click on the arrow of Control
  • Then click on the arrow of Class
  • Now under Class will be a list of devices identified with Numeric ID's
  • Look for this first numbers {4D36E965 then click on it
  • On the right oane window it will show you info about your DVD drive, just look for UpperFilters and LowerFilters right click and delete both then close the registry editor
  • I suggest that you restart your computer and then try burning again
If the problem still occurs then most probably you can try reinstalling Nero, also make sure that there are no other burning software on your Computer that may cause confusion with the detection of the DVD drive.
Reinstalling windows can be done to fix the issue as well, but is the last option if all else fails.
I hope that this helps.
Thank you for choosing Fixya,
mvincentc
Jun 07, 2011 | Computers & Internet
Windows boot manager failed to start - message - a recent hardware or software change might be the cause. I don't have a repair disc and it will not reboot. Thank You L
sorry to hear about the problem
I've used easyBCD to repair a windows boot manager, you may have to download it in another working machine, then burn it as bootable cd (using nero or similar image burning software), pop it in and when you start your computer make sure you have your cd/dvd drive unit as the first boot option so you go right into the cd ,
try the following instructions here to see if they may help, post back if you have further questions
repairing bootmanager
hope this helps
thank you!
May 16, 2011 | Advent Netbook
Help. i'm a novice... how do i burn my photos onto a cd with my 48x max cd-rw?
Dear friend follow as i say 1)insert cd into the drive 2)u can burn in two 1)burn using any 3rd party softwares like nero ,power iso etc or 2)burn using window inbuilt cd writing wizard......i recommend this 3)select files u wanted to burn to the cd 4)send them to cd drive 5)and select the cd drive and start writing data to cd........... hope this helps u .......rate me if u like it...........
Nov 28, 2010 | Dell Dimension 3000 PC Desktop
TDK Life on Record 1-16x speed DVD-R keeps failing when writing. I have burned about 25 dvds from this TDK pack, and all burn normally right up to near the end when my Nero burner software notifies "Burn...
You could try diferent burning software.it may even be a hardware fault the dvdr drive.cds and dvds burn and read data from inside to outer edge.as the laser moves out twards edge the speed of disc changes to compensate for larger distance travelled so a worn drive can sometimes start to show this fault.also sometimes only play half a film or stop at track 10 on cd
Apr 19, 2017 | Computers & Internet
Nero problem
You should reinstall your nero software and DVD/ Writer should be on master and CD rom shoul be slave. Then it will work at all.
Thank You
Jul 30, 2009 | Sony Optiarc AD-7170S Burner
Won't burn CD-r or DVD-R
make sure that your program that is setup to record. i.e nero-img burn et,c. is set to look at the drive D:- Or E:- whichever letter your drive is assigned by the computer.
Also try using a different Blank-media. if any disk has failed a full write, without finalizing Or creating the Table Of Contents. It will read as Empty Or Blank. you can see This By looking carefully at the underside of the Disk, to see whether it has been burned by the laset. ( Towards The Centre ) if the Dye is darker on the inner-edge, then this is possible.
You can also try using a different Packet writing software, or re-install the program.
Hope this helps.
Mike @ Compurepair.
Feb 22, 2008 | Sony DRX-710UL DVD±RW Dual Layer...
Nero cr-rw burner install
is your hard drive the master on the primary cable? You shouldn't need a digital audio cable unless you want digital audio. Are you using Nero software witht he drive? may have to re-install the software, or better, uninstall it, clear the registry with CCleaner (free download on the web) and then try a fresh install.
Dec 13, 2007 | LG CED 8120B CD-RW Burner
Writing disc
There will be different answers for different people. Changing the writing speed to the slowest available (6X for me) may help you – it did not help me. However, after ruining a big pile of DVD-Rs, I seem to have found out what my problem is – there is a conflict between my Picture Motion Browser and my InCD Helper. Here is how I got to my conclusion (I am running Windows XP Professional and have Nero 6):
On Friday, I spent over an hour on the phone with Sony Support (“SS”). SS had me create a new folder on the C:\ Drive, open Picture Motion Browser, select a media file, click the disc creation icon and on the settings tab of the disc creation window: (1) change the “Location of Temporary Files” to the New Folder and (2) check “manually select a writing speed”. Then I started the disc creation process and selected the lowest writing speed available to me (6X). At 50% I got the “Authoring Tool” error and the disc would not burn.
SS next had me restart my computer in Safe Mode (hitting F8 as it starts up) and select “Safe Mode with Networking”. Then I was able to burn several times without an error (even at “Optimum Speed”). Before I got off the phone with SS, he suggested that I disable all items at startup that are not necessary.
Yesterday, I clicked “Start”, then “Run” then typed “msconfig” in the Box, then clicked “OK” to bring up the System Config Utility. On the “Startup” tab (with my brother’s help) I disabled most of the startup items because they were not needed (if my brother was not familiar with a particular program, he looked it up on the internet to see what it did). Among the programs I disabled were InCD (InCD.exe), Nero Back it Up (NBJ.exe) and Nero Check (NeroCheck.exe).
After a Restart, I then tried, in normal mode, to burn a DVD-R with the New Folder/6X setting, with no luck. Bad burn.
My brother then suggested that I go back to the System Config Utility, click the “Services” tab and check the box “Hide All Microsoft Services”, so I could see only the non-Microsoft services that were running (I had 9, which included InCD Helper).
I disabled all the non-Microsoft services, restarted and tried to burn a disc at 16X – GOOD BURN. I then enabled InCD Helper (and kept all other non-Microsoft services disabled) and tried to burn – BAD BURN AT 50%. Next, I enabled all the services except for InCD Helper – GOOD BURN. Then, did another good burn. Then another.
So, turning InCD Helper off seems to be my work-around for using Picture Motion Browser (I kept the temp files location set to the New Folder). Of course, I will need InCD Helper to format my Read-Write CDs. Maybe InCD in Nero 6 is a problem but not in Nero 8. Also, For some of you, there may be conflicts with another program.
Hope this helps.
Nov 22, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
DVD burner will play but not burn
in device manager... remove ide controllers.. all of them.
reboot an it reinstalls automatic then retry..
also make sure burner is master on ide and reader is slave... if not try burner by itself as master and see what happens. there was a bug of xp and intel sata sometimes writing then it was blank.. slaved burner on secondary when sata present or something to that point.
Nov 07, 2007 | Computers & Internet
Acer Aspire 5600 Series 5630-6951 Laptop Logo
842 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
