Question about Refrigerators
Our GE Arctica PSS27NHN has gone out. We took a look inside and found the motherboard has a burnt spot, so that is most likely our problem. Can anyone tell me if this model is on the recall list. I have tried opening the list from previous posts, but the document does not open. Thank you!
  • Refrigerators Master
  • 1,606 Answers
No recall list that I know of .G E now has 2 boards available . The pt# you need is WR55X10656 . Less problems than a board for each model .
Posted on Jul 19, 2009
  • 1,543 Answers
Not on any recall, but if there was a burnt spot on the board, I would also replace the freezer (evaporator) fan, which is most likely what caused the burnt spot on the board. Replacing the board without replacing the fan motor will result in another burnt board.
Need motherboard info for pfsf6pkxabb
Not a solution but if you need a motherboard I recommend going to GE. I purchased one & it was cheaper than Amazon or anyplace else I could find.
Mar 15, 2014 | GE Profile Arctica Stainless Steel Top...
Have a GE Profile Arctica that is a few years old. It is "clicking" every couple seconds, like turning off and on constantly. I have been gone for a week if that matters. The HRS light is...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Dec 29, 2010 | GE Profile CustomStyle PSI23SCR Stainless...
Its making a clicking noise from the control board in the back of the fridge. It wont stay cool any advise would be nice ty.
When the GE control boards start clicking they have gone bad and must be replaced.
Board cost approximately $150.00.
Sep 06, 2010 | GE Profile Arctica Stainless Steel Top...
My ge profile arctica fridge is reading about 42 degrees, but the freezer side is working fine . Its about 5 years old, a tech took a look at it and said the fans and fuses looked fine... any ideas?
u probably are starting to get an ice up behind the freezer compartment or your fan has stopped blowing the air into the freezer first thing is to make sure the fan is blowing the cold air into the fridge side if not then there is your problem if you do feel the fan blowing then you would have to carefully remove the rear panel and check in the areas that have willcall them holes tat go into your fridge if they have ice built up inside of them if they do have ice then you have a defrost problem and would have to be aqble to perfom a continuity test on the deforst thermostat and the defrost heater if both of these are fine the next thing that you would look at would be your defrost timer check for the air and the ice and if you stillhavent found the problem write back hope this helps
Jul 21, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerators Logo
211 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
