Question about Stanton STR8-50 Turntable
Belt Loop I recently, on accident, removed the belt from it's place. Now I can't seem to figure out how to get that back on properly so I can play records again...
Hi, If you take the platter (The Silver Wheel) off you will find that you will have a little tiny motorised wheel, you need to wrap the belt around that little wheel aswell as fitting it aroung the platter. Hope this helps.
Posted on Nov 21, 2007
How to replace the alternator on a 2003 Mazda MPV
Disconnect the battery at the positive terminal by turning the bolt counterclockwise. Disconnect the alternator's terminal by turning the nut counterclockwise and removing the loop from the terminal bolt. Store these connectors away from the battery.
Remove the belt by pressing on the tension pulley arm firmly, then sliding the belt form underneath the idle pulley wheel. Release the tension pulley and the belt will slacken; it can then be removed from the alternator pulley wheel.
Remove the alternator by turning the mount bolts counterclockwise, then sliding them out of the mount arms. Some models may have mount bolt heads that must be held in place with a wrench while turning the nut. With the mounts free, the alternator can be exchanged for a new unit. Position the new alternator into the mount arms and slide the mount bolts into place, locking them down with the nuts turned clockwise.
Wrap the drive belt around the alternator pulley wheel (groove side down), then press the tension pulley arm and slide the belt back under the idle pulley wheel. Release the tension arm and the belt will automatically adjust to the proper tension.
Reconnect the alternator's terminal loop by placing it over the bolt and turning the nut clockwise. Connect the battery by turning the positive terminal bolt clockwise.
Oct 21, 2010 | 2003 Mazda MPV
How to fix a stuck seat belt VW GTI 2009
I just solved the problem for a stuck rear center seat belt in my 2002 Jetta.
Flip the base seat cushion forward against the front seat backs. Trace down along the belt to its tether point on the floor. The belt is sewn around a steel loop. The loop is anchored to a black steel hook. A thin silvery retainer plate is spring tensioned on top of the loop to prevent it from sliding off of the hook when the seat back is folded.
Therefore, you need to press the silvery retainer plate away from the hook (push up) to allow the loop to be slid from the hook. The belt was tight with the seat back in the upright position, so it was necessary to fold the seat back forward to create slack in the belt. Now push the belt loop towards the trunk and slide it off of the end of the hook (only possible with the retainer plate pushed up out of the way).
Now with total release of tension on the system via the bottom end of the seat belt being untethered and with the seat back returned to the upright position, normal extension and retraction of the belt will be reestablished. Next, simply extend the seat belt and slide the loop back into place over the floor hook. It snaps past the silvery retainer plate without all the effort required to hold the plate up during removal of the loop during disassembly.
Check again, the seat belt should be extending and retracting properly. Now just put the seat cushion back into regular position and you will be able to safely buckle up three people across the back seat.
It took about as long to do this repair as it has taken to post this answer to the problem. Note, the seat belt safety mechanism only allows normal extension and retraction of the belt when the seat back is upright.
Nov 29, 2009 | Volkswagen GTI Cars & Trucks
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
How to place belt on dryer drum
Take the hanging part of the bottom of the belt and place a finger through the bottom and pull it toward the belt tentioner , you may have to pull the tentioner with your other hand until you reach the motor shaft , loop the part of the belt your holding with your finger around the motor shaft , that should be it. Hold the drum straight and roll it clockwise a full turn to ensure it is correct.
Let me know how this goes.
Phil
Apr 10, 2009 | Dryers
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Replacing drive belt
The belt does NOT figure 8, it does not cross itself at all, friction would wear it out fast
the belt makes a kidney shape around the drum and motor and tensioner pulley, then the tensioner presses against it
de47d73.jpg loop the belt around the drum
pull the tensioner HARD to the end of its travel, loop the belt over the tensioner
release the tensioner
Aug 28, 2008 | Zanussi TC7114W Electric Dryer
Help need to replace beltplease help turntable
FAIRLY SIMPLE...
1) REMOVE THE PLATTER
2) WRAP THE BELT AROUND THE INNER CIRCLE FOUND ON THE BOTTOM SIDE OF THE PLATTER, THE BELT SHOULD FIT PERFECTLY....
3) PLACE THE PLATTER BACK INTO PLACE...
4) THROUGH ONE OF THE SPACES ON THE PLATTER, TAKE THE BELT AND PLACE IT OVER THE MOTOR WHEEL...THAT SHOULD DO IT.
Aug 18, 2008 | Pioneer PL-990 Turntable
Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
May 13, 2008 | Fantom Vacums Lighting Canister Vacuum
Zanussi TC7114W condenser Drier
belts do not figure 8
they look something like this
f6516ed.jpg the front panel comes off, to access the drum without removing bearings etc, and the belt can be placed easily, around the drum and motor pulley.
then pull the tensioner hard against its spring, loop the belt around the tensioner and allow the spring to tension the belt.
Feb 14, 2008 | Zanussi TC7114W Electric Dryer
Stanton STR8-50 Turntable Logo
168 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
