I have provided the instructions on how to program your remote to your TV and addressing the remote to your receiver below. I hope this helps.
Remotes: Basic (Television Only)
Turn the Television On.
Press and Hold the TV Power button for three seconds until the LED flashes.
Enter the three-digit code using the buttons on the number pad.
Press OK.
Note: The LED will flash three times.
Test functionality with the TV.
Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote:
Go to System Info screen.
Hold down the SAT button until all mode lights light up.
Enter a number between 1 and 15 using the numeric keypad on the remote.
Press the pound (#) button.
Once the SAT button blinks three times, press record.
Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
You will need a sonicview or viewsat switch spliter 110 port 1 119 port2 then go into your menu and ajust the settings 110 tp is 12258 and 119 is12239 and make sure you have the freq on the correct setting11250 scan each alone then save.Also set what typelnb you have on there to hope i helped
did yopu hook the wires up on the back right?Remove the wires and try turnning it on with no sat or wires hooked up if stilldoes that you will need a bringdead viewsat back to live file and try that way.hope i help :)
I have a VS2000 ultra which is currently on a AB switch with a Bell Satellite dish I am having frustration and difficulty getting any kind of transponder response to the viewsat! What am I doing wrong?
