Question about Cameras
When I insert my SD card that I have always used before into my hp Photosmart M525 digital camera it reads card has wrong format press ok to format card so when I press ok it reads unable to format. How do I format my card?
    President:
  • 2,559 Answers
Use your pc
Posted on Jul 19, 2009
Card wrong format
if you are meaning the sd card is in the wrong format insert the card in a pc and reformat to the correct format...or you could try to download killdisk exe install to pc (its freeware) and erase the card then insert into camera it should recognize it...
Dec 10, 2013 | HP Photosmart M525 Digital Camera
I put a new SDHC card in my camera(hp photosmart m525) and its telling me that the format is wrong then when i follow instructions its telling me that i can't format the card
The M525 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in the M525.
Dec 28, 2010 | Cameras
I just purchased a sandisk sdhc card 8gb memory card.how do i my camera says it is the wrong format.press ok and it will format it....i pressed the ok button and it says unable to format.can you help.
The problem is that you're using an incompatible memory card.
Your camera is designed to use SD memory cards up to a maximum 2GB capacity. Click on this link for the user manual and look at the specification on page 43 under the heading "storage".
You're trying to use an 8GB SDHC: not only is the capacity far too large for your camera to handle, but it's a later technical standard which your camera does not have the hardware for. SD and SDHC cards may look the same, but are very different "under the skin". SDHC compliant devices are backwards compatible with earlier SD cards, but SD devices like your camera cannot be updated to use SDHC cards.
Your only fix is to replace the SDHC card with an SD card of no greater than 2GB capacity.
Please take a moment to rate my answer.
Jul 30, 2010 | HP Photosmart M525 Digital Camera
New memory card unable to format
if there is a little slide on the side of the card try moving it to its other position either up or down
Mar 25, 2009 | HP Photosmart M525 Digital Camera
Card unable to format
Take the Camera & connect the PC.
Than format with FAT32 format or FAT.Before format please ensure the write or delete protected items in it.
Feb 01, 2009 | HP Photosmart M525 Digital Camera
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Sep 29, 2008 | HP Photosmart M525 Digital Camera
Card reads wrong format
Remove the memory card and look for the white tab on the left side of it. Make sure the swith is in the up position.
Jul 15, 2008 | HP Photosmart M525 Digital Camera
Wrong format on HP M425
Just fixed this problem on a M525 camera (same physical construction).
Do a search with M525 and format.
Feb 10, 2008 | HP Photosmart M425 Digital Camera
Cameras Logo
490 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
