Question about Korg Mr1 Digital Mobile Recorder
Fatal error on the korg mr-1
Hi,i have got a Korg mr-1 last year.when i unpplugged it from my computer i ve a new message on my screen:fatal System error.And i can t load anything to restore it.I can t stop the mr-1.please help me.i tried to format the hdd but it refused this action.Do i need to format the mr-1 as a disk after a backup?
3 Suggested Answers
joemaffei
  • 3 Answers
SOURCE: a broken key on my keyboard Korg Trinity
I just fixed this exact problem today. It took me a while to figure out how to get to the key bed, but it's not impossible. I'll try to retrace my steps and describe them as well as I can:
- Turn the keyboard upside down on a table with the joystick hanging off the table. To make my directions easier to follow, the joystick should be on your left. When I say "front", I mean towards the keys, "back" towards the knobs.
- Have 3 cups for the different types of screws you'll find. A magnet-tipped screwdriver is *essential*, as some of the screws are hard to get to, and you don't want to lose them in there.
- Start by removing the bottom plate.
- Remove the right side panel -- there should be three bigger screws towards the front, and two smaller ones way down towards the back.
- Here's the tricky part... unplug all connectors from the center board. You might want to take some detailed pictures before you do that because there are some empty sockets on the board. It's actually easy to figure out what goes where because most connectors are of different sizes.
- Unplug the two red connectors that go to the left side of the key bed, and the one that goes to the small board on the key bed, but NOT the small white one. That's the aftertouch cable and it doesn't need to be disconnected.
- Unscrew the center board from the horizontal rail in the middle of the case. There should be 4 screws and a cable tie is connected to each one. There are 3 black screws in the back around the digital output slots (there wasn't a digital card on the Trinity I worked on.) -- unscrew those and remove the board VERY carefully not to pull any wires along the way.
- There are two silver plastic grounding slips -- one on the far left, one on the far right. I know you have to remove the left one, I'm not sure about the right one, but remove it just in case.
- Unscrew the long aluminum piece at the very front, the one that is under the keys when the keyboard is right side up.
- Unplug the small connector off the floppy drive. You can leave the ribbon cable connected. The are 4 screws (I think) that hold the floppy drive in place. Unscrew those and remove the drive.
- There should be 1 more screw holding the key bed in place, and it's right by one of the floppy drive screws. Get that one out and pull the key bed upward using the metal piece in the middle -- it may be stuck to the horizontal rail, even though it's unscrewed. Pry it up gently with a screwdriver if you have to. The key bed should come out. If it doesn't, check what might be keeping it in place. Don't ever force anything out of a keyboard.
OK, that's part one. Part two is fairly easy...
- Set the key bed on a table. Remove the long plastic strip at the top.
- To remove a black key, first you have to remove the two surrounding white keys. Grab the bottom part of the key (where you play it) and push towards the top (where there's a square hole). Pay very close attention to how the key is removed, because reinstalling it is the same way, just reversed (obviously). There's a flat spring underneath the key, don't worry if it pops out. It's pretty self-explanatory how to put it back.
- Remove the black key in the same manner. Most likely, the little tab that hooks the key onto the key bed is chipped or broken. In any case, you will need a new key -- unless, of course, it was just the spring that popped out.
Follow the instructions in reverse order to put it all back together. I typed this by memory, so I may have skipped a step or two. Taking this keyboard apart wasn't as easy as I expected, but not as hard as it looked. It just takes patience and being careful.
I hope this helps!
Posted on Jun 04, 2009
mrniceneasy
SOURCE: Korg PA800. Ram Upgrade
The pa800 has a fixed amount of Ram at 64mbs and it is not physically possible to upgrade the Ram. The pa2x has a removable128mbs Module and that can be upgraded via a 256mb Module from Korg.
Keith [mrniceneasy - KorgForums]
Posted on Apr 09, 2010
Korg pa 800 gone dark
Sounds like your keyboard screen is going bad, You need to contact Korg and order one, you can do it yourself or they have authorized repair shop around your house.
Good luck
Jun 10, 2014 | Korg Pa800 Synthesizer
I need manual for korg concert 3500
From the original site of korg (http://www.korg.com/Support) there is nowhere the model u r describing.Please make sure u have posted the correct model description.
Aug 01, 2012 | Korg Music
Korg pa50 freezes at start up and only says "KORG PA50"
I think it is time for you to buy one new one....That you can but on side for parts.
Apr 04, 2012 | Korg Pa50 Professional Arranger Keyboard...
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Jul 16, 2011 | Korg D888 8 Track Recorder
I have a old (but almost unused) Korg d1200 recorder. Recently started getting disc error messages. Followed manual instructions to check disc drive and still get same results. Powered it up just now to...
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Jun 17, 2011 | Korg D888 8 Track Recorder
Want to replace my korg triton lcd touchscreen.where can i find a new one?
You will have to go to Korg to get the replacement screen.
Here: http://www.guitar-parts.com/catalog/korg/korg-touch-screens-lcds
Wow ... $300... ouch...!!!
Mar 30, 2011 | Music
MR-1 cannot be mounted via USB
I cannot connect my Korg MR1 to my computer MSI wind with Windows XP via USB port. The computer does not see the hard disk
of the Korg MR1
Jan 19, 2009 | Korg Mr1 Digital Mobile Recorder
Korg Mr1 Digital Mobile Recorder Logo
265 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
