SOURCE: Dehumidifier does not collect water.
If your
dehumidifier doesn't seem to run often but the humidity in the room is
high, try adjusting the humidistat control on the dehumidifier to a
dryer setting. If the dehumidifier seems to run constantly, but there's
little or no water in the container, there may be a problem in the
refrigeration system. Try cleaning the unit. If that doesn't work, you
can't repair the refrigeration system yourself, you need a qualified
appliance repair technician to do that.
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
SOURCE: kenmore dehumidifier is running but not pulling water
normally this means that the compressor is not running. Check capacitor and connections to compressor.
David
SOURCE: Kenmore 54501
Normal
0
When you push the power button, the blower fan comes on. In
a few minutes you should hear a second "click"--that is your
compressor starting. Do you hear that second click?
SOURCE: What setting should I set my dehumidifier for %
THE LOWER THE % SETTING, THE MORE MOISTURE THE DEHUMIDIFIER WILL REMOVE!!!
I have a Provic dehumidifier mainly to remove damp from walls in my 1900s terraced house ( 3rd DPC failed, another on its way). I've read a lot about the technical side and all I wanted to know was 'do i set it on the highest or lowest % to extract moisture from the walls'. I rang the Managing Director at Provic (his contact details are given on their website) who was very helpful. He advised that the lower the setting, the more damp would be removed from the walls and therefore the air, as the water passes from the wall into the air. My DH ranges from 40% to 70% so he advised me to set it at 40% in the worst affected room to remove as much moisture as possible from the walls. As the moisture is removed, the DH will collect less water and set itself to the correct level anyway. He advised me that when as much water as possible has been removed from this room and the DH % will not drop any lower, to move it to a more central position in the house, such as the hallway to then start setting the rest of the house to the correct humidity level. I set the DH to 40% and left it on overnight closing all doors to the affected room and removing containers of water such as a vase of flowers. When I got up in the morning it had switched itself off as it had already collected 3 litres of water! You do have to be careful not to over dry the air as everything, furniture and electricals, naturally needs moisture, but for a short term, quick drying solution, this level is ok.
Hope this helps!
