Question about Dell Dimension 8400 PC Desktop
Replaced Motherboard HELP
I have a dimension 8400 that needed new mb. Replaced that and the problem i had was corrected, however, the new mb doesn't recognize the hard drive tried making changes in bios but still nothing.
  • 5 more comments
  • michscha Nov 19, 2007
    Don't see it in the Bios, it is a SATA hd have checked the cables. Haven't changed any jumpers, It has the original OS on it from dell was thinking it has something to do with that but not sure how I would get around it because while trying to do a clean install from different xp pro cd but it doesn't find hd after booting from cd either
  • michscha Nov 20, 2007
    still no luck here i have reset the bios, I did a bios flash with correct version. that helped that the diagnostic lights on the back say the hd is there now but still will not find it in bios or while trying to install xp
    Choices under sata operation are
    Raid autodetect/ahci
    raid autodetect/ata
    raid on
    combination
    I know the hd is good cuz i hooked it up to a different computer and it was found.
    Im starting to think the motherboard i recieved is junk
    No not using raid and ive tried it on the combination setting which says its for sata pata settings
  • michscha Nov 21, 2007
    The motherboard is u7077 bought online oem part
    Dell Dimension 8400 A09 System BIOS Gotten off dell website for flashing. The Sata cable is fine i used it when i tried hd in different computer. Hard drive is getting power can hear it trying to run when it is plugged in it just spins and does like a click like it has no idea what to do. Stumped here thats forsure unless its a bad motherboard
    Hi again yep i have tried all the sata connections so im callin the company today and having them send me another motherboard. Hopefully with luck that will take care of this nitemare lol... Thanks for all your help
    Sniper:
  • 51 Answers
Have you looked into a third party driver? also alot of the time...you have a secondary bios if you will, that exists outside of your normal bios that you would/could use to setup your sata drive.......hope that helps
Posted on Dec 11, 2007
  • 883 Answers
Try resetting the BIOS with mobo jumper
Posted on Nov 20, 2007
  • 205 Answers
So the HD is not recognized at all or do you see it in the BIOS? If you don't see it at all then obvious things to check are the power cable, and the IDE or SATA cable. If it's an IDE drive it's not too difficult to bend a pin while attaching the connector. I would check that. I'm guessing you did not change any jumpers on the drive. Last thing I can think of is to be sure the BIOS settings are correct depending on if it's an IDE or SATA drive.
Posted on Nov 19, 2007
  • 6 more comments
  • ohiotom Nov 19, 2007
    I really think the problem is a setting in the BIOS. I don't have a DELL 8400 so I can't tell you where to look, but there are different modes you can choose from with respect to SATA and PATA. I would just experiment with them to see if you can get the motherboard to recognize the SATA drive.
    Just a bit more information for you. I rebooted the system I'm using here and found the SATA/PATA settings under IDE Configuration. You can choose from SATA, PATA, or SATA+PATA on my BIOS. I need to run SATA+PATA because I have SATA hard drives and a PATA DVD drive.
  • ohiotom Nov 20, 2007
    Were you able to locate the IDE configuration in the BIOS. These settings are available to you even if there is not HDD attached. If you did find it, how is it configured? PATA, SATA, or SATA+PATA?
    Are you using RAID? If not, you might try disabling it.
    Maybe we should back up.
    You said you replaced the motherboard. What motherboard is in the computer now. Is it from Dell or somewhere else. What is the model number.
    What BIOS and version are you running.
    You said you know the drive works because you put it in another computer.
    In my mind that leaves the following things as possible problems:
    The BIOS settings, the motherboard itself (even though it's new), the power cable to the HDD, and the SATA cable to the HDD.
    Have you tried a different power cable and SATA cable?
    I know you're working hard to correct this and it's easy for me to keep saying the BIOS, but assuming the motherboard is good and the cables are good, that's all that's left.
    I would really like to know what brand/version of BIOS and motherboard you're using so I can see if I can find a document that covers all the BIOS settings.
    Thanks.
  • ohiotom Nov 21, 2007
    I found this website where some folks are discussing boot problems on the same machine as yours with an SATA drive. Here's the link:
    http://www.techspot.com/vb/all/windows/t...
    They recommend changing the SATA setting to "combination". Probably worth a try.
    I know I'm a broken record, but it's either the BIOS settings or the motherboard, and I'm betting it's the BIOS settings.
    Just realized you said you already tried "combination". Sorry I did not see that before.
    Did you try all the SATA connectors on the motherboard?
    Well good luck. Sorry we could not figure this one out. Maybe it is a bad motherboard afterall.
    The only other thought I had is maybe there's a motherboard jumper that enables/disables the SATA interface.
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
When trying to boot PC all i get is black screen and message:- X300 SE 128MB BIOS P/N 113-A33406-100. Have replaced bios battery on motherboard an checked connections etc but still displays same message....
no problem friend please open your cpu shutter and you can see here a cell like watch's cell plug it out and replace it with the new one and start your computer now your this problem is 100% solve. thanks
Jul 14, 2011 | Dell Dimension 8400 PC Desktop
Dell 8400 dimension desktop on start up the fan runs at top speed like a jet engine taking off, and power light is constant amber with a blank screen. I have removed ram and grafics card etc and replaced...
Your power supply or motherboard has a problem. You can try getting a power supply on the internet ( $25 to $75) first. If no go then motherboard (about $100 to $200 ). The 8400 is about 6 years old which is the average lifespan of computers. One last thing you can try is removing the heatsink assembly and re-seating the processor. You have to clean the old thermal compound from the CPU chip and heat sink and reapply the compound (thermal paste). You might be better off buying a new computer from Walmart.
Feb 26, 2011 | Dell Dimension 8400 PC Desktop
My 6 year old Dell Dimension 8400 quit working completely.
Depending on the symptoms, you may have different faults.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber power LED, normally power supply
AAGG Diag LEDs normally bad RAM
Solid Amber Power LED, bad motherboard or Expansion card connected to it.
If you need a motherboard a Precision Workstation 370 motherboard is essentially the same and is available, (8400 motherboards are scarce)
http://shop.ebay.com/i.html?_kw=T7787&_kw=DELL&_kw=Motherboard
Feb 05, 2011 | Dell Dimension 8400 PC Desktop
Best motherboard that will fit the case of my Dell 8200 PC. I want more ram and maybe upgrade the processor.
The best MB for that chassis that will fit without any Modification is a Dimension 8400/PWS370 Dell Motherboard. The chassis power button/USB connection is a proprietary Dell connector and using any 3rd party MB will require modification and the wiring is almost impossible to find for that control board.
For just about the same cost (MB, Processor, Heatsink/Fan and RAM) you can buy a New Vostro 220 with a Core 2 Duo processor w/3GB RAM and a 320 GB HDD and it is under warranty
Dec 30, 2009 | Dell Dimension 8200 PC Desktop
Dell dimension 8400 will not start.
no man try to take out the modem ( last pci slot on the botom of the board) and see if you have any luck if not you going to need a new motherboard thanks and good luck
Oct 11, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 power supply
It not a common problem. The problem that you are facing is is beacuse of faulty motherboard. The blinking amber is caused , becasue the motherboard is not able to distribute the power signal to the devices . You can follow the link below to trouleshoot the problem if you are comfortable in opening the computer chassis
http://tinyurl.com/8mkpnm
Thanks
Proton
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Burned pins on psu
the reason for the melting could be down to one or the other, i would deffinately change the motherboard as it may be the reason for the melting and just keep an eye on the PSU
Sep 25, 2007 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
467 people viewed this question
Alun Cox
