Question about RTO Mini Quads
49cc 4 wheeler
The four wheeler started and died. we tried to start it this morning and there is no spark. we tried a different spark plug with the same results. it turns over but will not start. what should we try next.
  • 850 Answers
Check fuel delivery & filter
check for dirty & or loose or boken coil wires
these coils are a problem on these little guys!
very cheap to replace though!
Posted on Jul 20, 2009
90cc four wheeler won't start
Check for spark.make sure it's ON . pull plug and rest plug on bare metal and turn it over . If u see spark in plug gap it's not stator or coil or Cdi .,., it's a fuel issue chase it from bottom up carb to tank
Nov 12, 2016 | ATVs
How do i re-jet my carburetors on a 2007 suzuki LT-A 400F four wheeler?
when engines not running turn the gas off . And it sounds like you need to adjust your throttle pin that goes into the carb take the clip off the pin and move it down one good luck
Nov 23, 2012 | RTO 125cc ATV Quads Full Size Adult four...
Dinli 50cc 4 wheeler-has spark/new battery/getting fuel- won't start
Check your fuel is getting to the spark plug .If fuel is making the plug wet then one tip is to heat up the spark plug and with gloves on and acting very quickly replace plug and try to start .
Mar 14, 2010 | Derbi GP1 125 Racing Motorcycles
We have a New ATV 250cc that will not start..getting fuel,getting spark, engine just turns over!
  1. eHow
  2. Car Repair & Maintenance
  3. Car Oil Maintenance
  4. Drain Car Oil
  5. How to Repair a Polaris Four Wheeler
How to Repair a Polaris Four Wheeler By Brianna Byrne, eHow Contributor repair-polaris-four-wheeler-800x800.jpg Spark plug inspection and adjustment can be one way to repair a Polaris ATV.
Almost every vehicle needs regular servicing and repairs in order to continually perform at its best, and Polaris' lineup of four wheelers is no exception. The company has released dozens of ATV makes and models throughout the years, ranging from sporty racing quads to youth models to heavy-duty utility ATVs. Despite the differences between the company's many makes and models, general repair tips and troubleshooting instructions remain consistent for all Polaris four-wheelers. The electrical, ignition and fuel systems are some of the most common sources of Polaris ATV problems.
Read more: How to Repair a Polaris Four Wheeler ' eHow.com http://www.ehow.com/how_8074861_repair-polaris-four-wheeler.html#ixzz26pmQIzeh
Nov 21, 2009 | RTO 200cc Full Size Four Wheeler ATV
Why would a suzuki 4-wheeler not start. I have
Did you change the fuel filter? Is there a way to confirm that you're getting gasoline to the carburetor? If it fired once it should mean that you have spark to the plugs but there could also be a short in the kill switch circuitry that kills the ignition system. Pull a spark plug and put it in the spark plug wire socket, ground it against the motor and crank the engine and see if you're getting a good spark. Ensure that the air filter isn't dirty.
Nov 06, 2009 | Sport & Outdoor - Others
91 kawaski 4 wheeler won't start
first are you getting spark?second are you getting fuel? to check the spark take out the plug and put it back into to cap(holder) do not touch the plug and turn over the engine.you will see a small spark.if not you starter coil is bad.to check the gas look under the carb there will be a overflow hose by the overflow hose is a flathead screw,open it if no gas comes out you will need to take out the carb and replace the float valve.
Jun 15, 2009 | kawasaki KDX 220 R Motorcycles
RTO Mini Quads Logo
788 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
