Question about McCulloch Garden
I picked up this McCulloh chainsaw at a yardsale a few days ago. I am not sure if it takes regular gas or 2 cycle gas...and the oil-- could you tell me the mixture? It is a gas powered 32" chainsaw. Other than the 'M U C' engravings, theonly detectable writing I can find on the saw is one number printed under the filter top/cap. thanks for any help you might be able to give. :-)
    Problem Solver:
  • 13 Answers
It will take 2 cycle mix. I run all of my saws at about a 40: 1 mixture. I could likely run them at 50: 1 even but 40 is a little safer. The older saws had to have a richer mix due to the oils not being as good back then, not to mention the changes in engine technology. You can buy the 2 cycle mix at just about any hardware store. It will have a chart that tells you how much oil to mix in with the gas for a given ratio. If you really want to be safe with an older saw you might try it at 32: 1 Hope that helps you.
Posted on Jul 19, 2009
I have a Ryobi 4-cycle S430 weedeater. Do you use regular gas? If so,what type of oil do you use?
A 4-cycle engine requires regular gasoline whereas a 2-cycle engine requires oil to be mixed with the gas.
A 4-cycle engine requires regular gas in the gas tank and engine oil in another tank. Your owners manual will tell you what grade of oil to pour into the oil tank compartment of the weed-eater.
A 2-cycle engine requires regular gas plus a certain amount of 2-in-1 oil mixed with it. The oil that is mixed into the gas container and shaken together to "mix" the gas and oil before pouring into the gas/oil tank helps to lubricate the moving parts of the engine like the piston movement between the piston and the pistons' wall known as the cylinder wall. Also the oil aids in the creation of a tight seal which causes compression to occur that is responsible for optimum operation of the engine itself. It also provides lubrication to the piston rings and reduces friction as the piston rings push against the cylinder wall.
4-cycle engine oil can be purchased at any oil store like Canadian Tire/Sears/Napa Auto Parts. Just ask for oil for your weed-eater and let them know that your engine requires 4-cycle engine oil. I am sure the service clerk will point you in the right direction.
I hope this helps!Have a great day!
Apr 01, 2017 | Ryobi Garden
Looks like oil and fuel is leaking or blowing from exhaust.
John - Husqvarna makes really good power equipment that seldom offers trouble. The unit you are talking about is a 2 cycle system, meaning you mix oil and gas together in lieu of having an oil sump at the bottom of the engine like 4 cycle motors have. First question, did you mix a bottle of One Mix 2 cycle oil to a gallon of regular gas to start off using your machine? If you did, then I would think your unit is badly flooded, which happens a lot with 2 cycle equipment. Try taking out the spark plug and see if the spark plug looks wet from too much fuel. If it is, leave the spark plug out for a day or so to allow the cylinder head to vent the gas fumes. Replace the wet spark plug with a new one and try to start the unit again. Here's a tip: If you do flood a 2 cycle piece of equipment (trimmer, chainsaw, blower, etc.) again, make sure the choke is off and hold the throttle trigger wide open. Pull the started cord several times until the unit starts to run. Keep holding the throttle wide open until it clears itself out. Remember, you run the equipment, it does not run you :-)
Aug 01, 2016 | Husqvarna 223L 24.5cc 2-Cycle Straight...
What is the correct oil mixture for mac 130
If you are using McCulloh Custom Lubricant, mix 40 parts regular gasoline to 1 part Lubriocant (put 3.2 fluid ounce of Lubricant in 1 US gallon of regular gasoline).
If you are using SAE 40 weight two cycle oil, mix 20 parts regular gasoline to 1 part tow cycle oil (put 6.4 fluid ounce of two cycle oil in 1 US gallon of regular gasoline).
Oct 20, 2014 | Garden
Can not remove screws to get to oil pump on mcculloh 3516
Some screws have thread locker on them to keep them from falling outfrom vibration. Take a look if this is the case. If it is you can try heating the screw with a soldering iron only if the screw is in metal with no plastic touching it. See if the screw will come out now that it is hot.
Dec 02, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Regular gas (not 2 cycle) was put in my Poulan Pro chainsaw
If it was not run, or was shut down before it seized, drain the fuel
refill with 2 cycle mix (double oil if the saw had been run).
Start it and run under light load till empty.
if it seized a total rebuild will be necessary.
Oct 21, 2013 | Garden
What kind of gas
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
Dec 08, 2010 | Garden
I have a Makita chainsaw and have forgotten what kind of oil it takes
Use regular bar and chain oil for the oil tank. Use modern synthetic saw oil for the fuel mix. Both are available from home centers, hardware stores, and saw dealers. Be sure to premix the fuel and oil in it's own can and agitate thoroughly before refueling the saw. Hope this helps!
Jun 09, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Does 2 cycle oil get mixed with gas on McCulloch chainsaw or just put gas in?
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 14, 2009 | McCulloch Garden
Chainsaw gas/oil mix ratio
I have two Stihls that are well over 20 years old. I use the factory recommended mixture, 1 part 2 cycle Stihl oil to regular gas. (1:50)
That is still what the factory recommends. Don't use a cheap 2 cycle oil, go to a Stihl store and buy their 2 cycle oil in the orange plastic bottle.
Jun 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
96 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
