SOURCE: Asko W6431 Quattro front loader
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
SOURCE: Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
SOURCE: Clogged drain cleared, still won't drain
There is no reset switch on the pump, or program options. If you have cleaned out the drain pumo and it still does not work, you may have a bad pump.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
For future reference: to avoid a messy clean up when cleaning out the drain pump, you can use a wet/dry shop vac to pull a vacuum on the drain line at the standpipe to drain the wash tub and drain lines.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions do apply.
SOURCE: Washer displays Sud and will not drain. We waited
You are using too much soap. Sud warnings are telling you the motor is over heating due to excessive amp draw on the motor from trying to get them suds under control. You must only use HE soap and sparingly. Remove the bottom panel and open the cleanout. Wipe it down and flush it out. You will find the tech sheet in there. It will give you the ability to diagnose the problem as well as a list of fault codes.
Manual and codes of a duet washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have a LG TROMM front loader washer(Wife's
Hi, ..,/.
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
