SOURCE: remote code for my ge universal remote
http://www.jascoproducts.com/support/universal-Remote-codes.asp
All GE UNIVERSAL remote codes.
SOURCE: ge universal remote rc24912-c
guamboy1,
Here's a link that should get you everything you need...
http://www.remotecodelist.com/remotes/
Bill
hello and if you think the guy above me is too confusing then use my shorter version of what he is tring to say.
1.Press and hold both the tv and ON-OFF button
2.Press and release the PLAY button. If after five seconds, the component does not respond,
continue to press the PLAY button every five seconds until it turns off
3.When the component turns off, press and release the REVERSE button, then wait two seconds
to see if the If the component does not respond, continue to press the REVERSE button
every two seconds until the component turns on again.
4.press and release the STOP button. to save the program
..really is it that hard to say this
Type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page.
Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
If it takes a 4 digit code try these ones: 0053, 0189, 0227, 0456, 0024
If it takes a 3 digit code try these: 024, 033, 053, 189, 198, 227, 456
You can find the full instructions and manuals at the following link:
Good luck and please post back if this helps.
http://www.jascoproducts.com/support/universal-remote-codes.asp
