Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron 32" just powered off by itself and won't turn back on.
I was watching my TV and it basically shut off like it would if I turned it off with the remote control. I checked the outlet where it is plugged in and it is fine. There wasn't any electrical storms in the area either. The standby light won't come on...nothing at all happens when I try to turn it back on. What do you suggest???
  • 1 more comment
  • Anonymous Nov 24, 2007
    My tv goes off by its self. The standby light is on but the tv will not come back on.
  • marvac Mar 11, 2008
    The TV just cuts off after being on for 5 mins then the red light stays on . I turn it off and wait a few mins then cut it back on it may last 5-10 mins then cuts off again. the more I try the less time inbetween.
  • kris01 Mar 27, 2008
    Sony Trinitron 32" just powered off by itself and won't turn back on. Checked outlet and plug is fine. TV set up to DishNetwork receiver, it is working fine. No picture, no sound, is it dead forever?
Pull back off . fuse by end of power card may have blown.
Posted on Mar 31, 2008
  • 45 Answers
Sounds like you all have a bad bulb that needs replaced.
This is a common problem.
Posted on Mar 21, 2008
Sony wega engine 3lcd. turns itself off
It must be dlp tv that use lamp, is it?
If its true then replace lamp in tv that reached to end of its working life span and causing problem.
Your question shows it is CRT tv but symptom says it would be dlp tv.
Let me know if you have additional question about tv.
Jul 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Canno turn the tv on.
You probably have a main or high voltage power supply problem; the latter produces the 20,000 plus volts for the CRT and gets its voltage from the main supply. It's difficult to say which is at fault without a few measurements.
Feb 14, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
I have a Sony Triniton 27 inch Model number KV27S42. It shut off while we were watching it, then it shut off. We got it to go back on and it shut off again. The red light stays on. It sounds like it wants...
power switch is not the problem .Unit is shutting down to protect itself from an internal problem.Very possible it needs repair .Try to find an authorized Sony dealer in your area if possible
Aug 05, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv shut itself off while I was watching.
The power supply will need to be replaced. You can get them for $30 plus dollars and solder them in.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV shuts off
needs an IC in the power supply, very common sony problem, expect to pay $150 - 200 Julio
Jul 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv shuts itself off randomly
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron 32" was watching and it just powered off and I can't turn it back on.
solder the horizontal drive .and horizontal output transistors and transformers
Nov 19, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
93 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
