The fan motor do not start it just make a sound , but it do not run
  • 614 Answers
Bearings are out or you have a bad capacitor. Either way you need a service tech to check it out. Russ
Posted on Jul 19, 2009
The AC makes a humming sound when starting the fan. If I spin it by hand it runs. Model 620315.321 serial 90716722.
The humming sound is the motor trying to start, if you turn it by hand, usually they will run. it sounds like the motor for fan needs cleaning and oiling. God-Bless ya all!
May 20, 2016 | Dometic Rooftop RV Air Conditioner
Dometic roof air compressor comes on but fan will not replaced both capacitors and thermostat
Sounde as if there is an open winding in the fan motor. There are two sets of windings in a fan motor. The start winding and the run winding.
Here is how you can tell if it is the start winding. Put the unit on and then take a stick and try turning the fan swiftly. If it does start and it could be in either direction, since you have already replaced the capacitors then if the start winding is open then you will need to replace the fan motor. Same goes if the run winding is open.
Apr 14, 2014 | Dometic Rooftop RV Air Conditioner
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Cooling fan cannot get started by itself once it starts....if you give it a little touch it will start. Could it be the fan motor?
Yes that sound exacly like a bad motor,by giving it a little help and it starts and runs that means power is at fan motor to let it run,it would not run if power wasnt there so since power is there everything else is fine and sending power to fanmotor and it just wont start. By replacing that fan it will run byself without and help. Reply back with EXACT model number and i'll give you the part number so you can get replacement motor. and while i think its the freezer fan motor your talking about?is it the freezer fan or the one by the compressor?
Gene
Aug 17, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
The ac is not fully turning on. It sounds like the compressor starts to run, but the fan does not and eventually turn off. With the unit off, i turn the fan on and it sounds like its trying to run but its...
The first thing you should do is make sure the fan turns freely by hand. If it does then check the capacitor and replace it if it's bad. If the fan doesn't turn freely then you may need a new fan.
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Outside fan does not spin and a loud screeching sound coming from
Hey there, sounds like the bearings seized in your fan motor. You need to replace the fan motor. If the compressor runs without the fan, th pressures build up and if they reach an extreme point, the compressor will bypass internally, creating a loud sound as the high pressure is released to the low pressure side. I would turn the thermostat on and stand by the outdoor unit as it start. Leave the disconnect on the wall readily available so you can quickly turn it off. If the compressor sounds ok when it starts up and runs for a couple seconds, turn it off right away and replace the fan motor and you should be good to go. If the compressor sounds bad or real noisy immediately at start up, the fan motor not working killed your compreesor. You would need a motor and compressor, might as well replace the unit at this point if you are paying to have it done. Let me know if you need anything else
seth
Jul 03, 2009 | Carrier Heating & Cooling
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
