Question about Sony Xplod XM-1652Z Car Audio Amplifier
When i connect my power wire to battery my deck cuts off and when i disconnect cd player works
  • 34 Answers
This is your receiver going into speaker protection mode. this could be one of a couple of things based on what you have stated. The obvious would be that your amp is pushing too much power for your speakers. You can try a couple of things. 1st is check your watts for your amp and speakers and adjust your gain accordingly(may need to adjust how much your putting out). If it is turning off with the gain turned all the way down, then that's not the problem. Try disconnecting the RCA cables, then hook up to the battery and see if your amp comes on. If it does, you have everything hooked up right for the most part. Doing this will make sure your getting power to your amp.
If you get power with the RCA jacks unplugged, you might make sure that whatever speakers are hooked up to the amp are disconnected from the factory wiring. Those are some things to check based on what you wrote.. Could you be a little more specific with things like what kind of speakers and deck you have, how many speakers you are running, describe what happens when everything cuts off, etc.
Posted on Aug 03, 2009
I got a mtx jackhammer 2400 watt amp. when i hooked it all up and turned it on i am just getting 12 volt on the speaker output wires and no sound. it is just compressing the speakers and that is it. any...
verify your amps input. hook up a portable cd player with a headphone to rca "y" adapter to the amp and try that, to make sure it isnt an issue with the reciever/cd deck oir the input circuit. if the amp works correctly with the protable cd player/ walkman.mp3 player whatever, instead of the car deck, then something is wrong with your decks audio output. if it does not work with a secondary input device then perhaps you have the power hooked wrong. there should be both a red and yellow power lead from the amp, the red should be connected directly to the battery, and the yellow to the "acc on" (any circuit that turns on only when the car or stereo is turned on, sometimes connected directly to the stereo). both can be connected directly to the battery, but the yellow would need a switch, in that case, to turn the amp off when not in use.
Mar 09, 2011 | Car Audio & Video
The power buttons doesnt turn off and is there a
there is a power button on your deck, but you must get to the screen where the clock is, touch the button and it will shut off, if not then we need to trouble shoot the situation, which is easy, if you take out your deck. and if you can find the blue wire w/ the white stripe that is located on your deck this is your remote wire, this cut the deck on and off, when hooked up properly, first your gonna need to extend this wire, so it can reach the fuse panel, then you need to locate the fuse that says cigarette lighter, pull the fuse out, and stick the extended remote wire there, then reinsert the fuse. now the deck should be off, now if you put the key in and turn it to on, the deck will come on, and when you turn the car off, it will swtay off, this will work i bet my rep on it.
Feb 19, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
My Hyundai Elantra 2007 SLX no longer has a working CD Player. I put any CD in and get "CD ERROR" message. What can I do to fix this?
Next time you have the deck out before disconnecting the power turn the deck upsidedown.be carefull disconnect power either Battery or fuse for 10 min reconnect Power With deck still upside down insert CD and try and play. Remedy for Jarred CD DVD players even Game consoles. It realigns the Eye.
Jan 02, 2010 | Car Audio & Video
Deck wont power on
check the fuses on the stereo and on the car
Oct 22, 2009 | Alpine CDA-7894 CD Player
Digital Clock and cd player not working
it sounds like you have a bad connection either in the wiring or inside the deck itself. check the wiring for any loose connections or breaks in the wire.
Aug 19, 2009 | Car Audio & Video
Newly installed alpine resetting
Chevy stock speakers are 8 ohm. You should change out the stock speakers. Or at least dissconnect the back speakers and see if cd player still overloads and shuts off.
Feb 28, 2009 | Alpine CDE-9850Ri CD Player
Deck is powering off every 5 seconds
If radio stays on at low or no volume and cuts out when turning up you may have your battery backup voltage (yellow wire) droping below 10v under signal load. There is a circuit called backup check in radio that moniters Voltage It may seem ok when measuring without volume but under load it will fluctuate with the audio. Try hooking up Heavy guage Ground and Backup battery wires to prevent voltage loss across wires under load. Also check for any speaker that may not be producing proper sound when and if you can get radio working Disconnect wires to that speaker to see if radio will stay on. Just a couple of many possibilities.
kstahl65@att.net
Jan 12, 2008 | JVC KD-S890 CD Player
Same Prolbem as the other guy
Do you get sound when you use the radio? If so, the blue wire from the back of the radio needs to be disconnected and you need to use the blue/white wire instead.
If that doesn't work, try connecting either a test speaker or one speaker at a time. Your problem could be a short in the wiring - if the (+) wire to a speaker is touching the (-) wire, the deck will cut out all sound to keep itself from overheating. Let me know if you need more help.
Oct 12, 2007 | Jensen MP5720 CD Player
Newly Installed Car CD Player won't power up
When you see this problem, it usually means you have power on your deck's constant power wire (usually yellow) but no power on the accessory power wire (usually red). The accessory power wire is the one that sends voltage to the deck when the key is turned on. Usually this means that the red wire is either connected to the wrong vehicle wire, or that the vehicle's radio fuse is blown. As a last resort, you can disconnect the red wire from whatever it's connected to, and re-attach it to the same connection as your yellow wire. This should allow the radio to power up, but it won't turn on and off with the key-switch; you'd have to remember to turn it off or remove the face when you leave the vehicle, or you may drain the battery. Alternately, you can extend the red wire to a different source of key-switched voltage. Depending on the vehicle, you may be able to find this behind the cigarette lighter, at the key switch itself, or at the fuse box.
Jun 07, 2007 | Pyle PLMRA420 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
179 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
