Question about Dirt Devil CE6100 Featherlite Upright Vacuum
Cleaning solution will not come out when trigger squeezed. What could be the source of the problem.
  • 97 Answers
1.make sure that the sol tank is in there correctly. 2. when putting the machine together, the upper handle assembly goes on but you have to screw it down, if it is screwed down, the only thing that is left is the pump assembly that the guide rod hits. the rod hits this button inside of the machine and sometimes this gets jamed or all together stops working. the cause for this is usually from putting the wrong sol in the machine. hope this helps
Posted on Jul 20, 2009
Why doesn't the spray trigger release any cleaning solution when it is squeezed?
The water pump is most likely burned out and needs to be replaced. Carpet machines are notorious for broken water pumps.
Mar 07, 2016 | Vacuums
The motorized head starts as soon as it's connected without me having to squeeze the trigger. should this happen?
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your new DC44 - the motorised heads should definitely not be rotating when attached to the vacuum for storage. They should only rotate when you're holding down the on/off trigger and using the vacuum for cleaning.
I'm confident we can resolve this for you, and as your machine is so new it should be well within our free 2-year parts and labour cordless guarantee. Please email me directly at help@dyson.co.uk so I can take some further details.
I'll look forward to hearing from you.
Oct 14, 2014 | Dyson DC44 Animal Cordless Vacuum
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
It turns on, it makes the noises, the brushes are spinning, but the water/cleaner isn't getting to the floor
Hello! Sometimes it is necessary to prime the trigger to get the solution flowing. To prime the trigger, recline the handle and pump the trigger vigorously 60 times. Then, power the unit on and squeeze the trigger for about 60 seconds. The solution should begin to flow. It may be necessary to repeat these steps a few times. To avoid internal damage be sure you are only using the cleaning solution recommended for this unit. If the unit is still not dispensing we recommend taking the cleaner in to a vacuum repair center for repair. Follow the link to locate the nearest authorized service center to you. Service Center Locator
Jun 02, 2014 | Hoover Steamvac F5860-900 Vacuum
Cleaning liquid drains out whether trigger is squeezed or not
I put the soap tank on . Then went & got get the other holding tank it wasn't even on but all the cleaning solution was drained all over my carpet. What can I do to fix it or does it need to be returned to Wal-Mart
Mar 09, 2014 | Bissell PowerForce PowerBrush Deep...
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Ck
Aug 16, 2011 | Vacuums
I CANT GET MY BISSELL SPOTLIFTER MODEL 1716 TO SPRAY THE SOLUTION.
1) Make sure there is water in the solution tank.
2) Try priming the machine by instructing the consumer to squeeze the trigger
repeatedly for 1 to 2 full minutes. Important: If you cannot
squeeze the trigger all the way in, remove the tank from the back of the
machine and then try squeezing the trigger with the tank removed. There is an
internal valve that could be sticking. By removing the solution tank and squeezing
the trigger, it should break it loose, allowing the trigger to be fully depressed.
3) Make sure the open end of the siphon tube in the solution tank is not pushed into the
side of the tank, covering the end of tube. If it is, push the bend in the
Siphon tube toward the back of the solution tank.
4) Check to see if the siphon tube has become disconnected from the outlet fitting on
the inside of the solution tank. If so, you need to buy a replacement solution tank. Parts
can be found at www.bissell.com
5) Check to see if air comes through the spray tip by repeatedly squeezing the trigger
with solution tank off the unit. If not, spray tip may be clogged. Try and unclog
spray tip with a pin or paper clip.
If still no spray, please check the following:
a) Make sure the solution tank is installed properly.
b) Check to see if black O-ring is present on rear connector to solution tank.
May 28, 2011 | Bissell 1716 Spot Lifter PowerBrush...
Have a D4 model rainbow vaccum cleaner and want 2 no how 2 shampoo with it please help me
put cleaning solution into the proper receptacle lower brushes making contact with the surface to be cleaned. turn the on off switch on. start at the edge of the carpet squeezing the trigger for cleaning solution release and pull backwards.release trigger. roll vacuum back to begining position and pull backwards without squeezing solution release trigger. push back to the top slightly overlapping the first pass and repeat procedure. after rug is been completely shampooed allow to dry. after rug is dry sweep with broom
Feb 26, 2011 | Vacuums
Will not let any water out when i squeeze the water trigger.
Try squeezing the trigger a few times repeatdly. This usually works for me.
Mar 21, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Dirt Devil CE6100 Featherlite Upright Vacuum Logo
158 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
