Question about Cell Phones
How do you use the EasyGluco meter and the test strips?
What is a E-1 code for an ACCU-CHEK meter?
"E-1" in the display means the test strip may be damaged or the code key is incorrect. Remove and reinsert the test strip.
Jun 29, 2017 | Health & Beauty
What does E-7 mean?on my accu chek meter after inserting strip with blood?
It can mean one of a couple of things:
~An error occurred, when this happens you should turn it off, reset the unit, and turn it back on after at least 20 seconds have passed. You can also remove the battery and put it back in if you don't want to reset the meter
~You need to run a control test with control solution to realign the machine
~You inserted a used test strip or faulty test strip into the meter, try another strip
Mar 24, 2017 | Accu Chek Health & Beauty
Accu Check Active showing Trouble E-1
The electronic error code refers to either
  1. your glucose level may be extremely high or a meter or a test strip error has occurred.due to insufficient blood sample on the test strip.
  2. A used test strip was removed and reinserted.
  3. The test strip may be damaged or not properly inserted
Try turning the meter off and on or take the battery out for a few seconds and try testing glucose levels again. In any event, check your meter's manual; if unavailable- you can download an electronic version of the manual from the manufacturer's web site; or some meters you can browse the info from your meter's screen menu.
Other options, replace the battery with a new one or perhaps your meter has met its end-of-life usage.
Be well!
Feb 12, 2017 | Active Health & Beauty
What is E6 on a optimum xceed
It is the code for strip calibration, each set of test strips should come with a new calibration code key which is beige or white I think. Replace the 1 in the meter for 1 that came with test strips. Hope this helps.
Sep 07, 2014 | Health & Beauty
What are the error codes for Accu-Check Glucometers
E5 codekey expired which means that the test strips or out of date and no longer any good. You get a new codekey with a new can of test strips. A pain, I know.
E1 Re Insert test strip
E2 Incorrect code key
E3 Extremely high reading
E4 Not enough blood on test strip
E6 Control Solution too soon?
E7 Electronic error
E8 Temperature too high
E9 Change Battery.
May 13, 2014 | Accu Chek ACCU-CHEK Aviva Meter
My easy touch meter is reading way to high how do I fix it?
How do you know it is reading watch too high is my first question..MAKE SURE IT IS NOT YOUR GLUCOSE THAT IS READING HIGH..the tester should have a small bottle of testing accuracy with it..there are number scales on the side of the strip container and on the test bottle use a strip and test it..if it reads on or between the numbers the strips and tester is ok..if it does not, try another from another strip from different container..if it still reads wrong..your tester is faulty..good luck..
Apr 23, 2014 | Easy Touch No Coding Glucose Monitoring...
E-5 error code
  • Blood was applied to the test strip too soon. Slide and release buttonicon.gif to turn off the meter and release the test strip, then turn on the meter again. Repeat the test, waiting for the flashing test strip and blood drop symbol before touching blood or control solution to the end of the test strip.
  • The test strip was bent before the test started. Repeat the test with a new test strip.
  • There is moisture in the meter. Slide and release buttonicon.gifto turn off the meter. Let the meter dry at room temperature.
Apr 03, 2014 | Accu Chek Compact Plus Blood Glucose Meter
Error appears
Did new test strips come with a code key (small plastic piece that fits into machine) If it does replace chip in machine and use new one. Instructions will tell you more.
Nov 20, 2013 | Aqua Chek Trutest Digital Test Strip...
How do i also clear off all of these dangerously high blood sugar readings from the glucocard vital blood glucose meter?
Directions should say.try taking the battery out eat more veggies and exercise I've had it 41 years. God bless
Feb 25, 2013 | Arkray GlucoCard Vital Sensor Blood...
I HAVE NEW TEST STRIPS BUT THE MACHINE ASKS FOR THE CODE TO BE CHANGED AND I DON'T KNOW HOW TO CHANGE THE CODE. THIS IS MY SISTERS AND SHE IS ILL AND LEFT THE DIRECTION BOOK HOME. PLEASE TELL ME HOW...
Depending on which manufacturer made your sisters blood-glucose meter. The test strips some with one designated strip that will have the new code on it. Simply turn the meter on and insert the designated strip into the meter. It should automatically learn the new code for the strips you just purchased. If that fails, contact the pharmacy where you purchased the strips.
Feb 01, 2011 | Health & Beauty
Cell Phones Logo
155 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
