Question about Cyclone Exercise & Fitness
I have E2 come up after pressing start then treadmill stops.. WHAT DOES E2 MEAN ?
  • Anonymous Mar 12, 2014
    treadmill shows e1 & e2 otor starts stops
    Problem Solver:
Most likely needs a new walking belt, like mine.
Posted on Jul 20, 2009
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
My tunturi 620p has a e2 code how can i fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. check for tunturi treadmill articles
http://electro-medical.blogspot.com/
Feb 23, 2016 | Tunturi Exercise & Fitness
I bought a elite saracen treadmill n it says error code 4 what does that mean please n e wun help me pliz
reset the treadmills, follow this steps and fix it. GOD BLESS YOU
However you must RUN the software calibration for fix it. see your owner manual. or download free from www. fitness.manualsonline.com
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
GOD BLESS YOU
Nov 08, 2013 | Exercise & Fitness
Kettler mondeo e2 fault
Dear Sir:
Press the keys> stop+enter +quick start in sucession and go with key down up, until the error presss SELECT, for to quick star to clear the error log. Anyway read your instruction manual.
If you do not have go for free download: www.fitness.manualsonline.com
sincerely. God bless you
Apr 22, 2012 | Kettler Overstock Dual-action Cross...
The belt on my 68600F EverYoung has quit turning. The display screen is still on and says E2.What does that mean? gaylesues@hotmail.com
e2 normally refers to error in the speed sensor - iff the treadmill starts moving and then stops it is speed sensor related, otherwise if it never starts at all you will need to test your drive motor with an external 18v battery (cordless drill battery) to see if the motor will still turn. if it still turns then that narrows the problem to the motor controller which also means that the motor relays are not working and the controller would need replaced
Aug 04, 2010 | Exercise & Fitness
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
My Trimline treadmill 1050.E2 is showing an 'E2' on its screen and not working any more.
Hello all,
I have the same issue - it Shows "E2" on the time Display...
I already checked the Speed sensor and inclination potentiometer and both are OK... Moreover, I found that EEPROM Memory (Microchip 93LC46) is broken (reads "00"). After replacing it, I Need a way to reset / recalibrate the treadmill. I found on some Forums that there shall be a key combination (Speed+ & Start / Stop or similar) but None works for me. Could you please (if available) post the User Manual page describing the calibration entry? Or, maybe, advice a way to calibrate the 1050? Even the EEPROM Content (I guess the it is an issue) will be really helpful. Thank you in advance,
Milos
Oct 06, 2009 | Nautilus Exercise & Fitness
Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
May 12, 2009 | Exercise & Fitness
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
Exercise & Fitness Logo
466 people viewed this question
Top Cyclone Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Cyclone Exercise and Fitnes Expert? Answer questions, earn points and help others
