Question about Maytag Neptune MDE5500AY Electric Dryer
HI I have a 4yr old neptune dryer that will not heat, everything else works, I have checked all I know how to check, the element is ok, I think the thermal fuse is ok the only thing I can find is a small black device has two wires connected but on the back side is just a small black device smaller than a dine that has nothing connected to it the washer will not start with the wires dis-connected and it shows no continutity between the contact points, the motor and everything else seems to be fine Thanks for your help, Paul n avion@q.com
  • 4 more comments
  • navion671 Jul 19, 2009
    The dryer has been working just fine, the power went off and the dryer would not heat after that, how could that be a bad cord.?
    Thanks for youe info, what is the small device that has two wires connected to it, it is not on the heating element but on the other pipe and has a small black device on the inside it sort of looks like a sensor of some type, I get no continutity when I check this device and when I disconnect the wires the dryer will not run at all?
    By the way both wires that go to that device are pink.
    What does the high limit thermostat look like?
    HI Bruce
    I have done everything you suggested and no success, I have 123.volts to each side of the rec. the power cord meters out fine and the block inside the dryer also meters out fine and it looks like new. You did not tell me what the small device was that i asked about, that one has two pink wires going to it and when disconnected the dryer will not run, dont know if it is supposed to have continunity or not, what next? Thanks Paul
    hi bRUCE
    iS THEIR A WAY TO BY=PASS THAT ITEM, IF NOT, HOW DO YOU CHECK IT, DO YOU JUST CHECK FOR CONTENUNITY OR IS IT SUPPOSED TO READ RESISTANCE, i DID METER IT AND GOT NOTHING BETWEEN THE CONNECTION TABS
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
What you are describing could either be:
  • another thermal fuse but should read '0" ohms at normal temperature / condition;
  • sensor bar;
  • thermistor.
The exploded parts diagram starting here would help you identify it. Offhand though, it would appear to be not a part of the heater circuitry but of the general controller board.
To your concern on the heater failing to heat, some pointers:
  • there are 2 temperature sensitive protective devices in series with the heater. Failure of any would result to no heat;
  • the heater is activated by 2 switches; 1 in the controller board and another inside the fan motor;
  • below is an electrical wiring diagram that may be referenced to trace where the voltage would be missing hence no heater power.
HI
Good luck and thank you for asking FixYa.
Posted on Jul 22, 2009
    President:
  • 1,776 Answers
Sounds like you have been doing a good job. If the dryer won't heat, the problem is usually the thermal fuse, the heating element, or the high limit thermostat. All of these components can be easily checked with an ohm meter or multimeter. You could also check for a wiring problem. A common problem is for the main wiring connection from the house, at the dryer, to burn and break it's connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. Sure hope this helped and good luck.
Posted on Jul 19, 2009
  • Bruce Canfield
    Bruce Canfield Jul 19, 2009
    These are some pictures of high limit thermostats, so you have an idea of what you are looking for. Hope this helps.
  • Bruce Canfield
    That is the high limit thermostat. It was mounted on the pipe, right? It is most likely faulty and needs replaced.
  • 3,230 Answers
This is a common problem with wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
so you try replacing the cables.....
Good Luck!!
thanks
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Apparently the heat element has gone bad. Everything works, but no heat. It is only about 13 months old, could the heat element have burned out already and if so can a average repairman replace the part....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 22, 2011 | Samsung DV218AEW Electric Dryer
Maytag neptune dryer will run, no heat I think the heating element is out, how do I replace it. Model MD5500
heatman101
Sep 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer proble. The dryer works except no heat. Flame starts, but then turns off. Igniter element was checked and is good. What else should I check in order of probability? - flame sensor? -...
Hi
Thanks for using FixYa. Things that could stop an electric dryer from heating: - house fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not heat
Have a certified electrician check your outlet. The dryer requires 220VAC for the heating elements to work. If this is ok, check the heating elements it may be broken.If this is ok, check the high and low limit switches, this could be defective.
Apr 04, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
Maytag Neptune - everything works, not getting hot
check to see if it has an igniter if so that could be your problem.
Nov 22, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune breakdown
Warning! Shock Hazard! Disconnect dryer from power source before servicing.
I assume you repaired a wire that attaches to a white ceramic insulator terminal? If you have a volt-ohm meter, you can check continuity of the element and hi-limit thermostat and overtemp.fuse located on the element shroud. If you ddon't have access to a meter then visually inspect the element for a break in the coil. The fuse and hi-limit can be temporarily bypassed 1 at a time to eliminate 1 or the other being faulty. Also double check your heat temperature settings on the control panel to make sure it did not become de-selected. There are also temperature control thermostats attached to the blower housing in lower left corner of the dryer that can be temporarily bypassed to test for failure. Tip: Clean lint filter after each load. Clean vent to outside,(check every 3-6 months), and refrain from overloading dryer. This will help extend the life span of the element and the dryer itself.
Hope this helps!
May 26, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
117 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
