Question about Janome Memory Craft 9000 Computerized Sewing Machine
Machine quit like it blew a fuse
While i was using the embroidery feature the thread got tight and the needle got pulled onto the foot and broke causing the machine to just stop
  • 208 Answers
The 9000 has a safety fuse which blows to protect the circuit board from overloading. It is a simple 3amp fuse available at Radio Shack or automotive store.
If you are mechanically inclined, give it a try. If you are not, take it to a dealer who knows how to repair it.
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the base unit to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
One of the wires will not remove.
On the other side of the box, remove the two screws that hold the cover on.
Inside, remove the two screws that hold the board.
Inside you will find two fuses. One will be blown. Replace with new fuse and reassemble.
When refitting the base unit, make sure that the knee lifter is on the correct side of the lever. Also, orient the base so that the accessory bin fits properly.
After securing the base unit with the four large screws, test the knee lifter to make sure that you got it right.
You will then need to recalibrate your clothsetter if you have one.
Posted on Jul 19, 2009
  • zenash221 Sep 07, 2011
    Are there fuses in a Janome MC 10001? machine wont turn on could that be my problem?
  • Paul Howell
    Paul Howell Sep 08, 2011
    Yes, the 10001 has the same type of fuse.
  • 55 Answers
It seems that when the needle broke it overloaded the machine motor which has caused a fuse to blow.
the fuse is not user accessable so take it to a tech.
scott
Posted on Jul 27, 2009
How can I use my Bernina 640 Artista to applique
Perhaps I'm not understanding your question. When doing applique, I use a very tight zigzag stitch with a satin stitch foot or open-toe embroidery foot (so the thickness of the stitches do not create buildup under the presser foot). Set the tension so the bobbin thread stays mostly under the fabric so the top thread is the only thread that shows on the top (sometimes threading the bobbin pigtail will help).
Fuse the cutout fabric to the backing fabric. Then zigzag so the raw edge of the fabric is covered by the zigzag (helps to use a thicker thread so the coverage is easier).
Some newer machines have the ability to miter corners. On my 930, I set the needle position to the outside of the raw edged. Then when I near the corner, I gently, but consistently, narrow the stitch width to an an outside point, since the needle on the outside edge, turn the fabric and gently, but consistently, widen the stitch to full width. This creates a nice mitered corner.
When making curves, stitch small lengths and then sink the needle on the outside of the curve, and gently turn the fabric to follow the curve and repeat while going around the curve.
https://books.google.com/books?id=MQneD8cQ5KAC&pg=PA13&lpg=PA13&dq=mitered+applique+corner&source=bl&ots=1sHsUrkVAz&sig=1WZ-i2-T3RtvUEW797sHxTKiq4E&hl=en&sa=X&ved=0ahUKEwiaoZeiwunKAhVslYMKHewdDFEQ6AEIKzAC#v=onepage&q=mitered%20applique%20corner&f=false
How to Appliqu Like Pro Sew4Home (FWIW, IMHO, the satin stitch on the bird is really a poor example. The stitch is not very even at all--could be the sewing machine.)
How to Make and Apply Appliques (The giraffe is a better example, although choosing a simple design to applique usually yields better results.)
Practice, practice, practice!
Feb 08, 2016 | Bernina Artista 640E Sewing, Quilting and...
Why does thread keep shredding?
The needle could be bent or have a burr--try putting in a brand-new needle that is compatible with the thread size and the fabric you are sewing.You could be using old thread that has deteriorated. Also, bargain bin thread is not the best quality to use. The thread may be too big for the needle's eye. The upper tension may be too tight. Also, RAISE the presser foot BEFORE threading the upper thread since this releases the thread tensioner and allows the thread to seat properly.
This guide may be helpful:
Sewing Needle Troubleshooting Guide
also other helpful information:
All About Needles
Sep 05, 2015 | Janome MB4 Four Needle Embroidery Machine
Please help! I have a Brother Innovis 4000 embroidery machine. My machine is skipping stitches then the needle falls out or bends/breaks. This happens even after I changed the needle and rethread the...
I would double check your Threading. Make sure the thread coming from the spool is not getting caught on something. Try keeping the presser foot up, and then pull out some thread from the back of the needle, does it seem tight to pull? Now lower the presser foot, is it more difficult to pull out? It should be but not so much that it is bending the needle.
If it is to tight, there could thread caught in the tension discs. Remove the left side panel above the needle on the machine. Check to see if you can see any threads. IF not, lower the thread tension and see if that helps. Good luck
Apr 24, 2014 | Brother XL-3500
I have a Singer Quantum XL-100 Sewing/Embroidery machine that repeatedly and frequently breaks needles. In one 10-minute sewing session, it broke six needles. The tension at the top of the machine i
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Feb 01, 2013 | Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Skipping stitches and sometime the thread breaks.
Sounds like a tension problem maybe. Too tight tension will bend, and break the needle, especially if sewing fast in free machine embroidery, in this mode, the tensions have to be looser anyway. I can't explain why the wheel flagged and stopped, but experiment with tensions first.
Mar 27, 2017 | PfaFF Sewing Machines
The needle constantly breaks while embroidering. I tried every type of needle with no difference. It goes ok for a few seconds till the needle goes down and hits the foot and breaks. I do have on the...
Sounds like your tension is too tight and the thread is pulling your needle. Also, make your that you needle position button is on center. If it is on left or right it will cause your needle to snap.
Apr 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Dec 22, 2007 | Singer CE-200 Quantum Futura Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
361 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
