Polaris ATV Logo
G
Gilles Vaillancourt Posted on Oct 29, 2016
Why the fan on 700 polaris sportsman 2003 wont start when hot
jackwithrowjr
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 30, 2016
jackwithrowjr
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
253
Points
There is a temperature sensor on the radiator.If that doesn't work check wiring.
2004 Polaris Sportsman 700. Crank but no start.
Various ideas in the link.
Engines only need three things
Good fresh fuel to the engine.
A spark at the right time
Compression
https://www.google.com/search?q=2004+Polaris+Sportsman+700.+Crank+but+no+start
Wires getting hot
start with any accessories first than battery/connections and then lights ,cooling fan-and 12v plug and check 4x4 switch and actuator may be hanging up causing a draw
Will a 2002 Polaris sportsman ho 500motor and all accessories fit onto a 2002 polaris 700 sportsman frame
They're not compatible - officially. May just depend on how willing you are to make it work. Either way - the 2002 Polaris Sportsman 700 shows as only being compatible with the 2002, 2003 and 2004 Sportsman 700 & 600 - both models both years. Now - they look pretty close, but if you cross check (Looks like Polaris did a mid-model swap or something). There are (2) frames listed for the 2002 Polaris Sportsman 500 -
First Option - built before 9/3/01 Part # 1013325-067
01 - 02 SPORTSMAN 400
01 - 02 SPORTSMAN 500
01 WORKER 500
SECOND OPTION/AFTER 9.3.01 1013729-067
- JUST THE 02 SPORTSMAN 500
I attached the link to the schematic for you to see. To do a cross reference, copy the part number instead of pressing it (clicking on the part # a lot of the times doesn't show you full compatiblity). Then on the top banner, click OEM Genuine Parts, Polaris, ATV - there will be a parts search bar on the right hand side - paste your part # there and click search. If there are group compatibilities that they've added over time you'll see more than one 'where used' - just click on each one if you have to, but you'll see all compatible models.
copy part number
go back to page one of OEM Polaris parts
paste in search box
click on 'where used' in red to the right of the listing. If more than one - notate each as you go - but you'll see everywhere it was used. I've got a frame from a 2000 Polaris Expedition 425 4x4 with swingarm attached - I'd sell basically for shipping cost on ebay - if you're close to North Florida and in the area - I'd give it to you for $50, FYI. Here's a link to the listing and pictures in there - looks like a copy of the sportsman. If you get to zooming in on both and this looks like a match let me know. And a lot of parts were interchangeable for years on top of years from some parts - check out my ebay store (It's not finished but a lot of parts are on their) subscribe as a follower - and I'll give you 30% off your first order as a Thank You. I price to sell and compete, by the way - free shipping on almost everything - and all you have to do is shop around on there to see where I stand. 17 South Industries, LLC - I could use some help just gettting the name out there and word of mouth. All the best - Good Luck
2002 Polaris SPORTSMAN 500 ALL OPTIONS A02CH50 Parts
eBay Store 17 SOUTH INDUSTRIES:
http://stores.ebay.com/17-SOUTH-INDUSTRIES
Dec 25, 2015 • ATVs
1helpful
Wont go in 2 wheel drive but switch works light come on dash ?
2004 Sportsman 700 AWD not working..... - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Feb 18, 2013 - Go Back · Polaris ATV Forum > Polaris ATV Technical Discussions > ATV ... AWD wont engage. 2. The instrument / speedo works. 3. The AWD switch is ...Polaris ATV Junkie! .... four wheel drive not working polaris sportsman. Won't go into 4 wheel drive
Feb 1, 2013
4 wheel drive not working
Nov 13, 2011
2004 700, 4WD engages by itself
Oct 28, 2011
4wd is stuck on
Dec 3, 2009
More results from www.polarisatvforums.c
1helpful
On a 2004 polaris 700 atv what causes total loss of power wont even light up the instruments even hooking up jumper cables has no effect
check earth cable/s
dont jump start with a running car engine,it will send too many volts.
do you have spark?
Does a bad battery have any bearing on the efi of a Polaris Sportsman 700 2004?
If motor has to constantly charge a battery while running, it could use a bit more fuel.
Fan wont start on polaris 450
Check your fuse then trace your wires back from thr fan.you may have a bad ground or broken wire.
7helpful
4answers
2004 polaris sportsman 700, shuts off while riding.
I have a 2004 700 carb that shut off while riding and then would start up 3-5 minutes later after many nights working on it Ifinally figured it out no help from any dealer. There are 2 circuit breakers under the front rack mine were very rusted, Replaced both never had the problem again. My situation was always only when the lights were on.
Hope this helps
Aug 07, 2009 • Polaris ATV
Top Polaris ATVs Experts
john h
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Polaris ATV Expert? Answer questions, earn points and help others
