Question about Hayden Industries SuperVac 2400 Central System Vacuum
Odd noise coming from central vacumn cleaner
I have a hayden central vacumn ''superpack deluxe''--it makes a rattling noise when I use the beater bar--vacumns fine. Also some how the little red reset button on the top disappeared, I don't know if it is in the machine. Any help would be appreciated. Julie
My machine does not have a series number on it so I picked the 2400 in order to post my question.
  • 430 Answers
The rattling noise, will likely increase when the head is flipped upside down. Generally means you have a stone caught in the belt or a blown or stripped tooth on the belt.
If you gently squeeze the outside edges of the light housing it will pop off to reveal two screws to remove the lid. Check for other screws at the neck of the power head. Once removed your belt and brush will be visible. Remove the brush roll with end caps and flip the belt inside out rolling it between your finger , look for cracks or a floppy or missing tooth. Replace if any sign of wear.
Inspect the dust caps on your brush. There is a washer under each, likely buried in lint. Do not lose as these are a spacers for each end of the brush. Clean shaft and lube with WD40. Spray caps with the same. vacuum loose grit and dust bunnies away from motor and reinstall, your red button must align with the lid when replacing
Posted on Sep 07, 2009
5 Suggested Answers
  • 95 Answers
SOURCE: Can you replace the cloth bag in a beam central
It is not recommended to change that bag. The best thing to do would be to borrow a shop vac from someone and vacuum it off really good. The bags sell for about $60.00 and they are a big pain to change out. The other thing you can do to help the odor is look into exhausting the unit outside. All manufacturers recommend it.
Posted on Jul 01, 2009
  • 120 Answers
SOURCE: Brush will not turn
The most common problem is the handle isn't screwed in tight enough when the machine was assembled. Try tightening it down all the was and the electrical connections will then seat properly.
Posted on Jul 06, 2009
WonderTech
  • 268 Answers
SOURCE: the vacumn is running but the beater brush is not
This is from the Dyson website. It gives step by step guide for replacing belt and or beater bar.
http://www.dysonmedic.com/DC07%20Folder/DC07%20Belt%20&%20Brushbar%20change.html
Good luck.
Posted on Aug 10, 2009
VacuumRepair
  • 438 Answers
SOURCE: I need a Hayden Superpack Deluxe owners manual so
Hi There,
Actually Hayden uses Panasonic to make all of their power nozzles. Replacing the belt on your Hayden is the identical process to replacing the belt on Panasonic canisters. Kenmore canisters also use Panasonic power nozzles, it's the same process with these.
There is also a power nozzle overload switch on the top of the power nozzle that will shut down if anything is vacuumed up that causes stress on the belt. Try pushing this reset switch before opening up the power nozzle to install a belt. It may be something as simple as a reset switch.
If this doesn't work, here's a link to a repair that I've posted on Fixya on how to replace the belt on a Kenmore canister power nozzle, the process will be identical to your Hayden power nozzle.
http://www.fixya.com/support/t4563318-change_belt_sears_vacuum
Hopefully this helped you. Please be so kind and rate the repair, or leave feedback for the fixya community.
Thank you,
Chris
Posted on May 22, 2010
Dyson DC27 beater bar making noise
I'm sorry to hear you're having difficulty with your DC27's brush bar. If you haven't already been in touch with us, I'd encourage you to give our Helpline a call on 1-866-693-9766 (US), or 0800 298 0298 (UK), as we may be able to resolve this issue with some simple troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a built in vacuum with a Hayden Deluxe Superpack carpet nozzle. The vacuum works but the Superpack power nozzle does not turn on. Reset does not work. Are there steps for troubleshooting, or...
Find a local vacuum repair center. Could be a short in the hose. The PN could need a new motor or circuit breaker. It will be cheaper to repair than replace, but check the hose for current at the handle end.
Jul 02, 2010 | Hayden Industries SuperVac 6000 Central...
I need a Hayden Superpack Deluxe owners manual so I can change the belt
Hi There,
Thank you,
Chris
May 22, 2010 | Hayden Industries SuperVac 6000 Central...
I ran over a shoe lace and now it is making a loud rattling noise
The All Floors model has a protective belt clutch system and the rattling sound means the clutch has slipped. This would have to be repaired officially by a Dyson repairer.
Jun 15, 2009 | Dyson DC07 All Floors Bagless Upright...
Hayden SuperVac central vacuum making an unbelievably loud noise.
Stop using the vac. Remove the filter and clean thoroughly, inspecting for damage. If the vac is spiting out bits off fuzz or lint it may need the motor cleaned and serviced as dirt has leaked past the filter. If it is spewing black, not gray this is carbon dust from the motor brushes. If the noise is scratchy or growling this is a sign of a motor problem as well.
The muffler unless it is a hepa filter/muffler combination is NOT designed to catch dust.
Exhaust dust is a sign of dust leaking through the motor which indicates future moor problems.
HINT, if the guy who installed the muffler didn't secure it right he is probably not a good choice as a service tech either. The muffler is normally clamped or secured in place with a small screw so it can be removed in the event of service.
Jun 14, 2009 | Hayden Industries SuperVac 3600 Central...
Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hayden Industries SuperVac 3600 Central...
Hayden Industries SuperVac 2400 Central System Vacuum Logo
121 people viewed this question
Top Hayden Industries Vacuums Experts
JoeVacs
Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
