SONY WEGA KV-32FS320 STAND BY BLINKS 9 TIMES
  • 1 more comment
  • luvejoy Jul 19, 2009
    make a long story short what do 9 blinks mean?
    sony kv32fs320 stand by blinks 9 times
    no picture no sound
    will test and try solution , if its the problem your answer was quick ans very helpful thanks
  • 19,396 Answers
I guess that you already unplugged the TV for a while etc.
9 blinks, pause, 9 blinks means that there is a fault concerning the ZCD (zero crossing detector).
This is a common problem on the following models: KV27FS320, KV32FS120, KV32FS320, KV36FS120 and KV36FS320.
The ZCD is located on the A board. The A board is the large board at the bottom of the set. It may be released so that it will turn up into service position.
Q605 and D690 then Q690 and D647 must be tested. Looking for faulty components, replacing them and resoldering bad solder joints in the ZCD circuit will fix the fault.
You can find schematics on the service manual here: SM-KV27FS320
You can find parts here.
Please do not forget to accept the solution, typing and researching parts and manuals for your unit took its time.
Many thanks
G.
Posted on Jul 19, 2009
  • 441 Answers
Getting 9 blinks on Sony 32fs320. How do I fix and how do I remove cover to fix it
http://www.manualslib.com/manual/471404/Sony-Kv-27fs320.html?page=29
May 31, 2016 | Sony Televison & Video
My standy light keeps flashing and every so often it sounds like its gonna come on then it dont
There's no Picture coming out from the screen???even dark-fluctuating picture???
Does it blink?how many blinks interval?
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS320 32" TV
My sony wega KV-32FS120 wont turn on and the stand by is blinking 9 times
Does the tv blink 9 times and cut off and then try to come back on? If so change the switching regulator,also i would change D6116,D6301. they are all on the G board.use a desoldering iron,Oh,make sure the tv is unpluged from outlet.Also check for bad wiring connections,bad solder joints.Use a good solder for good connection like 60%Tin and 40%Lead Rosin Core.hope this helps...
Feb 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron wont power up
the red light flashing tells you and a service person why the tv will not power up . if you have test equipment to work on electronic equipment then we can move forward if not ,your tv will need parts replaced or board replaced . you dont have a failure that you can change a setting or push a reset button to repair . you will need to get in there with equipment inject signals,look at waveforms ,and check voltages . and know what you are doing with the information you gather ...the other answer you need to send it out for repair .... most repairs on this set will run 100.00-200.00 for common problems .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 31, 2009 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV stuck in stand by mode
Yes. The 9 blinks indiate a problem in the power supply area. I need to look up your specific model later today to get you the specific parts. If you are comfortable with soldering and working inside the set, you should be able to repair this yourself.
Stay tuned...
Dan
Jun 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-32FS320 5 blinks
Sony KP53HS10 5 blinks
Five blinks means "Video out abnormality detection". Possible problem areas are as follows:
Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510, 516, 524 (A board).
There are actually three C boards, the CR, CG and CB boards. They are attached to the rear of the red, green and blue CRTs, respectively. I wouldnt attempt to repair the set myself. I would solicite the services of an authorized Sony servicenter.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The stand by timer flash 9 times stop and start again
you have a regulator problem my friend in the power supply or there is a fault in the G board. This is not a repair an untrained person should attempt, please get a pro to assist you in this repair.
Jun 05, 2007 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
