Question about KitchenAid Microwave Ovens
Microwave doesn't heat & bulb burned out
I have a KitchenAid kbms377gbl0 combination convection oven/microwave. I have been living with the burned out light for some time, but now the microwave doesn't heat up. It seems to work (i.e., turns on, turntable turns, fan operates), but there is a burning smell through the vent and no heat is produced. I think I probably need a magnetron, but I would feel better if I could find a service manual and get some advice before I pull the unit out of the wall.
Thanks, Chris
  • guttormsson Jul 19, 2009
    Please give exact advice for this model - what are the specific steps I need to follow? What are the Tests to perform? How can I get a service manual?
    Thanks - that's what I wanted to hear.
  • 6,784 Answers
HI. your diagnosis is correct. this is the result of a failed Magnetron tube assembly. in most cases, the cut-off fuse will save the Magnetron during a current spike. IN this case, the Cut-off fuse has failed. The faint smell of burning circuitry has confirmed major trauma that has occurred in the unit. it is , mostly, isolated in the magnetron area.
It would be wise to inspect the H.V. capacitor for trauma as well. this is noticeable by discoloration around the Capacitor solder mounts. the actual capacitor should be swollen if traumatized by the voltage spike. if the capacitor, visibly, looks ok and, the shape is not compromised, this will rule out a combination issue concerning the Capacitor and magnetron tube assembly.
**(Although recommended, it is not necessary to inspect the capacitor if you have a functioning microwave with no heat. most models will be totally inoperable if the H.V. capacitor has failed. If the microwave is operational but, there is simply no heat, this will confirm a functioning capacitor(HV)
Concerning the service manual. I have searched for reasonable priced replacement parts and, the actual service manual as well. there seems to be a shortage of repair parts for this particular model. Kitchen Aide has also discontinued the actual print of the service manual you seek as well.
The actual listing price for the replacement Magnetron is $140.00. that hard part is actually tracking it down for purchase. Your model number has been discontinued.
Posted on Jul 19, 2009
  • KitchenAid Master
  • 19,396 Answers
To start check if there is a D on the display, that will indicate demo mode. Unplug appliance or trip circuit breaker for ten minutes to reset the appliance, that can fix minor problems.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts and diagram, Enter model number or contact the seller here to purchase parts.
Food in microwave is burning on edge and cold in the center
you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
Dec 29, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
My Kitchenaid combo convection/mw works on convect but has a loud humming and no heat on microwave.
A loud humming noise in microwave mode will usually be a shorted high voltage diode or bad magnetron.
Sep 16, 2013 | KitchenAid Architect II KHHC2090S ...
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Replace the bulb on a kitchenaid kems377d
The installation guide for KEMS377D is from Whirlpool for KBMC140. Follow the instruction how to remove the microwave from the cabinet.
Feb 24, 2012 | KitchenAid KEMC377K Convection / Microwave...
KitchenAid Architect II KHHC2090S Stainless Steel 1200 Watts Convection / Microwave Oven. Microwave quit heating. Inverter and magnetron replaced by the repairman. Still no heat but the magnetron gets...
Perhaps the "repairman" should take another look at it. A lot of microwave ovens have an aerial that directs the energy out to the load or food to be heated.
Maybe...maybe not but worth a look behind the waveguide cover I would say.
Mar 24, 2011 | KitchenAid Architect II KHHC2090S ...
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave lamp burn't out
You can find owner's manuals (which would cover any user-replaceable lights if present), installation instructions, and parts list, which have helpful exploded view diagrams here.
You can order parts here.
Jun 30, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Nov 08, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
57 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
