Question about Optoma EP716 Multimedia Projector
My Optoma EP716 projector will not power up; no warning lights at all. The lamp has less than 750 hours on it. Tried different AC cable but nothing. Took it down (ceiling mount), still nothing. Please advise!
  • 2,237 Answers
Power supply has a fuse on it. if the fuse is good, the power supply needs replacing.
Posted on Jul 22, 2009
I have an Optoma DS303 projector. It stopped working. We replaced the lamp and it worked for about 3 hours and then when we tried to turn it on again, it won't fire up. Sometimes if I hold down the...
Check the voltage at the lamp input from the ballast after connecting projector to mains supply. (Warning: Do not switch on the projector while checking the voltage. It will damage your multimeter) The lamp connection shall be removed. If the voltage is around 60 to 80 volts AC, then your ballast is OK. Check for fragments inside the lamp.
sonsunny
Jun 14, 2011 | Optoma DS303 DLP Projector
How do you install new light bulb
The Projector will detect the lamp life itself. It will show you a warning message renstrike_1.jpg
When you see this message, change the lamp as soon as possible. Make sure the projector has been cooled down for at least 30 minutes before changing the lamp
  1. Switch off the power to the projector by pressing the Power/Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use the screwdriver to remove the screw from the cover. (1)
  5. Push up and remove the cover. (2)
  6. Remove the 2 screws from the lamp module. (3)
  7. Pull out the lamp module. (4)
To Replace the lamp module, reverse the previous steps,
Feb 28, 2011 | Optoma EP716 Multimedia Projector
How do I remove the lamp on a optoma ep716?
Lamp Replacing Procedure:
  1. Switch off the power to the projector by pressing the Power/ Standby button.
  4. Use a screwdriver to remove the screw from the cover.
  8. Replace the lamp module in reverse the previous steps.
Nov 11, 2009 | Optoma EP716 Multimedia Projector
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
Optoma ep716 was making a clicking sound and now doesn't turn on... Any ideas?
Clicking is probably the lamp trying to start - it uses an electric arc to get going. Kind of like gas stoves using spark to ignite the gas. Odds are that the lamp is dead. If there are any indicator lights, and you describe them, we may be able to confirm (or disprove). 1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Jun 17, 2009 | Optoma EP716 Multimedia Projector
Dark or no image at all
CHECK THE LAMP IF THE LAMP LUSTER HAS GONE OUT OR THE FILAMENT AT DOWN PORTION IS BLACK THEN THIS PROBLEM HAPPEN
Dec 08, 2008 | Optoma EP716 Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 turns on but no picture displays
Don't ever just unplug the power cord while it is on. The bulb needs to cool down with the fan still on.
Did you ever connect a source?
Sep 17, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 source detection
It sounds like your module that controls the menu and the "cycling through" may not be in sync or may needs to be replaced. I had times have had to make sure the Optoma EP716 had to be first plugged in and "on" before the PC can communicate with it. Once the Optoma is "ON", then turn your PC/Notebook on. If there is no connection via USB, "S" cable and/or your VGA (be sure your PC/Notebook is set to have the external VGA "active"). Let me know if this works or not. Then we can try to move forward with other options for troubleshooting. BTW...how long have you had this multimedia and how many hours of use does it have?...JGUAM
Oct 21, 2007 | Optoma EP716 Multimedia Projector
Optoma EP716 Multimedia Projector Logo
893 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
