Question about LG WD-3243RHD Front Load Washer / Dryer
My washer/dryer is not draining properly.
My washer will not drain the water. I am trying to fix it myself but am haiving difficulties. It seems there are 3 ways to resolve this:
1. clean the lint from the an elbow tube. Does anyone know how to do this?
2. It may require removing the hoses from the pump but no idea how to do this either.
3. Last resort is to call a tech.
Any tips would be appreciated. Thanks
  • maxanderson May 03, 2008
    I have removed the drain obstruction.
    I took off the small electric motor and had electrician problem
    I remove the large tubing from the bottom of the obstruction
    What's next?
  • 489 Answers
If the pump is not draining, either the drain filter screen is clogged with debris, the drain pump is jammed by foreign debris or the drain pump itself has failed.  More than likely something is clogged in the filter screen or a sock is jammed up inside the drain bellows tube just before the filter.  Pull the drain filter screen out and look up the hole to see if there is any material stuck inside.  Usually that's the problem.
Posted on Apr 28, 2008
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
Jul 12, 2013 - Uploaded by
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
May tag washer doesn't drain water
the water pump must be brocken you should call in a specialist or try to fix it or you could try to fix it yourself this site might help
Feb 01, 2012 | Maytag Washing Machines
My Maytag Top Loader will only fill with water up to 3 inches then it continues to drain while the water is coming in. How can I fix this myself?
You may have a condition known as "siphoning". This is usually caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain (siphon) as it tries to fill. The following link explains:
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Aug 11, 2010 | Maytag Washing Machines
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
When starting the washer, it occasionally will not fill
Check the drain hose. The open end of the pipe the hose drains into must be higher than the top of the washer's tub (usually 30 inches or so off the floor, minimum) or the water can siphon right out. The drain hose should not be a sealed connection to the drain pipe. Try to extend the drain pipe up to about 36 inches off the floor level.
Jan 10, 2009 | Whirlpool Washing Machines
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
Water problems
If the washer doesn't fill properly, or if only one temperature of water fills the tub, something is probably keeping water from entering the machine or it's draining before the tub fills completely. Set the controls to the first wash cycle, and then try each water temperature setting. If both hot and cold water seem to be entering the washer with good pressure, water may be draining out prematurely during the fill cycle, through siphoning action. Be sure the drain hose's connection to the standpipe is at least 34 inches above the floor (otherwise, discuss the problem with a plumber). An air gap between drain hose and stand pipe that prevents backflow is also good to have. If hot works but cold doesn't, or vice versa: 1) Be sure both the hot and cold water faucets are turned on. 2) Be sure the supply hoses are not kinked. 3) Turn off the faucets. Unscrew the hoses from the faucets and drain them into a bucket. Hold the bucket under the faucets and test them to make sure they both work and have plenty of pressure (see HERE for information on replacing faucets). Screw the hoses back onto the faucets. 4) Unscrew the hoses from the inlet valves and clean the filter screens just inside them; these may be clogged. To do this, pry out the screens with a screwdriver (this can be difficult; the screens may be inside the valves), flush them under running water, then put them back into the hose. If the screens look defective, replace them. Then screw the hoses back onto the valves. Be careful not to cross-thread the hose threads when screwing them back onto the valves. 5) Call an appliance repairperson; there may be a defective inlet valve or a problem with the controls.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
LG WD-3243RHD Front Load Washer / Dryer Logo
354 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
