Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
The soap dish doesn't always open during the wash cycle
    Problem Solver:
  • 7 Answers
Make sure your dishes are not blocking the soap door. I have found that we have to make sure that taller items are pushed to the back of the dishwasher.
Posted on Aug 18, 2009
catriver
  • 878 Answers
SOURCE: soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Posted on Jan 16, 2008
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
SOURCE: GE Nautilus Soap does not dissolve
The Water Inlet Valve is not Working. This is a small piece at the bottom of the dishwasher where the inlet hose connects to. The Valve is stuck and water will not enter the dishwasher itself. Of course this is one of the most expensive pieces of the dishwasher to replace!
Posted on Jul 26, 2008
SOURCE: Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Posted on Dec 13, 2008
Karthik316
  • 187 Answers
SOURCE: soap dispenser does not open during wash cycle
  • Hi,
    please try this...
    imer:
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Posted on Apr 14, 2009
The soap door will not open during wash cycle, I tried both short wash & reg wash.
The only experience that I have with this type problem was from having dishes blocking the soap door. You can tell if this is the problem when you open the door. The soap door will then open and the soap will run down the door.
Apr 25, 2012 | Samsung DMT800RHS Dishwasher
The dishwasher completed it cycle but didn't use any dish soap and didn't clean the dishes.
It appears that, the soap compartment box did not open during the wash cycle. First check that whether this is the problem. If water flow is good and you are convinced that, the wash has taken place without the soap then, check the soap box relay latch ( if you can do it yourself.)
If this is not possible you have take the help of the service provider authorized by the co.
You can keep soap in a small cup and place it in the upper tray in a suitable place and run the wash till the repairs are attended!.
Oct 05, 2010 | Maytag Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Oct 26, 2007 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
104 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
