I need help setting the alarm on my radio controlled digital clock.
1- Turn over
your Seth Thomas digital clock. Use your finger to remove the cover to
the unit's battery compartment. Insert two AA-size alkaline batteries
into the battery compartment and replace the cover. Certain Seth Thomas
digital clock units will also have an optional alternate power source in
the form of a standard AC power cable that plugs into a wall outlet in
your home.
2 Place your Seth Thomas
solar-powered digital clock in front of a light source, such as on a
window sill or beneath a lamp. The black strip on the top of the unit is
the solar sensor, so as long as light is shining down on that strip,
your clock will be powered on and ready to use. The sensor stores energy
throughout the day so that it can work at night with no direct light
contact on the sensor.
3 Press the time zone button that
indicates your current time zone. These buttons are located on the back
of the unit. For example, if you are in the eastern time zone select the
"EST" button. Turn the unit back over. It will now be displaying the
correct time on its digital screen.
4 Use the "Alarm" switch (if
applicable) to enable and disable the clock's alarm. Press the "Alarm"
button, followed by the "Hour" and "Minute" buttons, to set the
appropriate alarm time based on your needs. Use the "Alarm HI LO" switch
to set the volume for the alarm.
5 Press the "Weather" button to
tune your Seth Thomas digital clock to its built-in local weather radio
station (if applicable). Certain Seth Thomas clocks have this radio
weather functionality built in, while others don't. If yours does, the
aforementioned "Weather" button will be located on the front of the
unit.
