Question about Irons
Sand is coming out of the vent holes - Irons
  • 864 Answers
Probably not sand but crystalized minerals from tap water. Heat up the iron then unplug it and add white vinegar. Shake it up and pour it out of the fill hole. Repeat if necessary. Then rinse it out with distilled or filtered water. Before using on clothes, fill with water and steam iron an old towel to get the vinegar smell out. Use only filtered or distilled water to prevent this happening again.
Posted on Jul 19, 2009
My steampress 660 is has black stuff coming out
Hi Beverly. The "dried stuff" is scale which occurs naturally in tap water. You should always use DISTILLED water - buy litre bottles (approx.$2.ea Home Brand) all supermarkets. Electricity off, empty out all the water in your iron. Half fill with distilled water, cover the filling hole, and shake water inside iron side to side, up and down, vigorously, empty distilled water out and watch carefully to see if water runs clear or has sediment coming out - may need to repeat this action. When water runs clear re-fill iron as normal with distilled water. Put iron on lowest STEAM setting, LIFT up iron but with soleplate facing down onto an old rag/towel (brown water may come out) press steam button on & off to try & clear the holes. Turn iron off, allow to cool. Thick cloth wipe soleplate over getting into the holes if they have not cleared. Triple wrap a wooden skewer in cloth soaked in white viegar or "scale remover" and circulate it around the blocked holes. Go very carefully do not scratch the coating on the soleplate or holes - very important. Let us all know how this goes please and if I have been of help, do hope so. Good luck, Chris
Feb 12, 2015 | Irons
How to open is 9050 rowenta precision valet to descale
Well this was helpful but also HELLfull! I guess because I have a 9050 !! I took out the screws & could not remove the hose it was attached with 2 clamps & a washer! I put the whole darn thing in my tub ( I have a sprayer in there) and yes tons of sand, black stuff and cloudy water came out. I had to do this 8 times with the hose attached! Awkward & a mess but it did finally come out clear. BTW I did it through the hose & the bottom hole. On the last run through, after my whole bathroom is soaked including me, the hose popped out! I was cracking up! turns out on the 9050 you simply push down on the ribbed hose covering and it releases. This IS NOT in the manual either. But I'm happy my steamer's like new again & live & learn ;o)
Oct 09, 2012 | Rowenta Commercial Garment Steamer - White
SAND LIKE SUBSTANCE COMING OUT OF IRON
Yes, there is a "Solution" you could use in the reservoir to remove the crud. First of all, STOP using tap water. What you have is mineral deposits inside your iron from using tap water. Use ONLY steam distilled water. I usually find this at my grocery store.
To clean out your iron, use white vinegar in your iron instead of water. This is to CLEAN the iron ONLY! Do NOT use to press cloths! And make sure the steam and/or water flow very clear (free from "sand", dirty water/steam or any other contaminates BEFORE using iron to press your cloths. You may need to flush the iron with water (remember, steam distilled ONLY) more than once to get all of the vinegar out.
Hope this helps...
Jun 29, 2012 | Rowenta Perfect Iron
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Jul 20, 2011 | Russell Hobbs 13153 Iron
Cloths steamer not working keeps saying its out of water but its not.
Suspect that your iron's steam holes are being blocked by calcified water (hard deposits)and need to be cleaned. Take one cup of white vinegar to one cup of water and pour it in the Iron. let it sit heating for about 30 minutes. Repeat if necessary. The acidic vinegar will disolve the calcium and unblock the vents. The final one after the vents are clear, 1 tbs of lemon juice to one cup of water gets rid of the vinegty smell.
Jan 10, 2011 | Irons
Brown coming through holes and there is a funny odor.
Tell us what water you have been adding to the iron over the years?
Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
Have you ever used Vinegar to try to clean out the chamber?
Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
Mack B
Dec 27, 2010 | Krups V70 Iron
Its not heating and steam doesn´t come out? where can i fixed or get parts?
Do you have limescale in your water? If so, the iron could be clogged with what looks like sand. Try bashing it around a bit and see if sand comes out the sides. If so, continue until no more sand comes out.
Apr 21, 2010 | Conair GS11 Iron
Krups V70 Iron - stopped working
Sand points on temperature control switch.
Jul 07, 2009 | Krups V70 Iron
I have something stuck on the surfance of my iron. I need to know what to use to remove it. It is staining my clothes when I iron.
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do this if it is teflon coated. Hope this helps you.
George
Jul 15, 2008 | Conair Compact Garment Steamer Iron
How many holes is it supposed to have
Sometimes is normal having different hole diagram on the iron Plate.That one is up To the engineer worked on the project.Some Company believe having more hole in the tip will increase the efficiency of your iron.Some other company believe having more hole on the side is better.If you have a chance to look a professional iron system..most of them have a triangle hole located on the tip and it`s been in that way for so long.This is different for regular home iron with less pressure and different Plate.
Fabio
Jun 21, 2008 | Rowenta SM700 Iron with Auto Shut-off
Irons Logo
153 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
