A month ago my a/c started to leak water.We called help & they pumped the tubes then they put freon,they said the leak is on the unit not inside the house,it worked for a week then the a/c stopped blowing cold air.So the company replaced the whole unit.After 2 days the temperature stated going high hot again.What can be the problem pls help.
  • 614 Answers
Could be leak on your indoor coil and they missed it. Call them back ask them to leak check inside. If they missed it it is their rsponsibility. to repair. Rus
Posted on Jul 19, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Why did fridge stop working, then freezer 4 days later?
how it works. 6 month ago another technician came to this service call and found out that system is low on freon. So he charge it up with freon and add leak dye into the system. Leak was really slow, so he could not find at first. Here Im 6 month later, found leak dye with special light (dye leak set (tools) cost about 180$), did not need to order any parts, but replaced copper tube. Customer paid around 600$ for repair total for this repair. Hope That Helps!
Aug 16, 2015 | GE GDS18LBR Bottom Freezer Refrigerator
I have 2000 grand am gt Ive been having a water leak problem for a few weeks now everytime I start my car I have to full with water and in the midst of trips usually needs water also I noticed it getting...
where do you live. Never put straight water in a radiator even during the summer. Do you see any leaks around the water pump, radiator hoses, or in the passenger side floor inside also at the firewall where the heater hoses go into the heater.
Apr 29, 2017 | Cars & Trucks
1997 Safari. A month ago, I replaced the water pump in my van. Now, It's leaking severely. I first thought maybe I didn't seal the gaskets well enough so I tore it apart, fixed that issue and put it...
You may have a hose to the heater leaking, or a lower intake gasket leaking. You will have to remove the engine cover to get a good look. If you have access to a cooling system pressure tester, it would realy help out.
Good hunting!
Apr 22, 2011 | 1997 GMC Safari
Hello, My condensing unit (LG-LMU245HV) and my wall unit (LG-LMN185HV) are brand new and were installed just one month ago. Everything has been running fine but now all of a sudden now the air coming...
Hi, when the copper lines at the condensing unit, the larger of the 2- start to form ice, you have a freon leak. The unit is new, so I would expect the leak to be at one of the welded/brazed joints. What will happen, is the indoor unit, the evaporator coil will start to ice over and block off all air flow through through the coil. I hate to tell you this, you will need to call the installer out to do a leak check on the unit. They will then need to pump it down, braze the leak with sil-phos, or silver solder and recharge the unit. This is the problem, I see this a lot on new units. Someone forgot to do a leak check on it. Being only a month old, it has to have a warranty on it, shouldn't cost you a dime, but this is the problem, indeed!! Please keep me updated on this and get them out there. It will never cool until they fix the leak and recharge it. Please don't forget to rate me on this, I know you will be kind. Keep me posted and you can contact me by my user name below. Thank you Zeke! You still have freon in the unit, just low enough to start the suction line outside to start to ice and loose your cooling.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 06, 2010 | Heating & Cooling
2 month long issue...RUUD Achiever 1.5 Ton 10 Seer Heat Pump
Rather than have him replace the control board first, ask him to remove all the freon and weigh it. He then can reuse the Freon that came out of your system put back in at the exact charge that the rating plate calls for. He will add a bit more to compensate for any length of refrigerant lines from the outside unit to the inside unit. Now this will bring us to factory specs. If the unit continues to act up, then try another board. I am not a big fan of replacing parts unless other alternative ways have been tried. If he is not willing to try what you ask, why is he there? As far as if something is taking out the control board, have him clean and reconnect all ground connections and inspect the thermostat connections both on the inside unit and the outside unit. Is lightning a factor in your area?
Mar 11, 2010 | Ruud Matching Split Air Conditioner
Chevy 350 runs really hot... i have an 81 cutlass with a stock chevy 350 & for some reason it bogs down like it wants to turn off & gets really hot when im parked idleing for more than 10 minutes...
there must be something restricting the water flow. i would check the houses to make sure there are no sharp turns that dont need to be there. next i would upgrade the water pump to make up for the extra hp.
flushing the block is always a good idea too when adding hp because you never know whats inthere.
Oct 25, 2009 | 1984 Oldsmobile Cutlass
Coolant leaking into engine Compartment
Sounds like a blown coolant hose, or a faulty coolant water pump.
Jan 19, 2009 | 1991 Honda Civic
Inside house is warm
Use the spell check and please restate your issue. Have you checked your air filter? Has the unit been serviced recently?
Sep 04, 2008 | Carrier 38CKC036 Air Conditioner
GE frig cooling problems
This Refrigerator was charged with leak dye about 4 month before it leaked out again. Got service call, there was sticker dated 4 month ago, thats what honest company do, even if other company will come out they able to see when it was charged with freon and if they add leak dye. Got my blue flash light - found right away dye, spayed with soap - bubbles right on the spot, replaced piece of copper tube - leak fixed! call right service man at first!
Jun 17, 2008 | Refrigerators
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
