Frigidaire FRT21P5A Top Freezer Refrigerator
Problem for Frigidaire FRT21P5A Top Freezer Refrigerator
Frigidaire freezer cold, refrig in 50's.
By richpoland on Jul 19, 2009
I had the refrigerator defrost timer replaced. The fridge worked good. My wife thought it was getting warm last week. I adjusted the temperature settings and the fridge went to 30 degrees. I have been out of town and she tells me that the fridge has warmed up to 50 degrees (we have a thermometer). My guess is the vent is not open enough. Where is it? Can she fix it? she has a lot of food in both he fridge and freezer.
Comments:
Jul 20, 2009
- If the defrost heater/thermostat isn't working correctly, wouldn't there be ice in the freezer? Since you had the defrost time replaced and the machine worked fine for three months and there is no ice, isn't another problem more likely?
Solution #1
posted on Jul 20, 2009
Not Rated)
Sea Breeze
Rank: Guru  Frigidaire Refrigerators  Expert
Rating: 90%, 772 votes
Yes pull the refrigerator away from wall and feel top of the compressor. Is it too hot to touch? Are bot fans running. Straight wire the thermostat to see if it is causing this. The start relay and start capacitor may be the reason. Let me know by email you response because Fixya has not been notifying me of any ones response to my solutions. I just found you made a response. Sea Breeze
Was this helpful?
Yes
No
Solution #2
posted on Jul 19, 2009
Not Rated)
Sea Breeze
Rank: Guru  Frigidaire Expert
Because the model FRT21P5A has a manual adjusting vent I believe your problem is either the defrost heater and defrost thermostat and or the cold control (thermostst) is not working correctly. When temperatures rise in the refrigerator side first that is a sign that the air flow from the freezer is restricted. You will need to unplug the refrigerator and remove the rear panel in back of freezer to confirm. If Iced over use a hair dryer to defrost and disconnect one wire on the defrost heater. Check the defrost heater with an ohm meter. You should get a reading. If defective and no reading you need to replace the defrost heater and defrost thermostat. Let me know what you find, Thanks Sea Breeze
Comments:
Was this helpful?
Yes
No
Popular Solutions for Frigidaire FRT21P5A Top
Questions and Unsolved Problems for Frigidaire FRT21P5A Top
Do you recommend Frigidaire FRT21P5A Top Freezer Refrigerator?
Answer
Answer
my frigdaire is a top freezer model with ice maker, today I noticed I did not hear it,,i opened it... (More)
Answer
There is water under the two crispers - any help is appreciated.
Answer
i have an amercain fridge freeze and the temp in both side drop if i turn it on again it gose back... (More)
Answer
Few weeks ago my fridge stopped cooling. We have since replaced but I want to keep as a spare for... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Newport, KY
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
