Question about HP Officejet Pro L7680 All-In-One Printer
Printer Jammed, now wont work.
This is the second HP L7680 I have had, first one went back under guarantee, with technical problems.
This time it jammed once on a single sheet of A4 plain paper. I carefully removed the jam, but the printer will simply not function. It seems to jam the print heads when it runs from across the surface. It never gets as far as printing, as a single "sweep" of the print heads makes it jam in the middle. I have tried power off, carefully move heads & star again, but still jams.
Its very annoying as is hardly used, and when it is, all i get is problems!
I hope someone can help !
Bill
  • 3,230 Answers
The full instructions are located here -
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&lc=en&dlc=en&cc=us&lang=en&rule=29041&product=2512009
Post further comments for more help...
Good Luck!!
Thanks
Posted on Jul 19, 2009
Message "clear paper jam" when there is no jammed paper.
disconnect the power cable from the back of the printer
press and hold the power button for 20-30 seconds
reconnect the power cable power onn the printer
beforte doing all these carefully check for bits af papers insiade the printer at the rear access door also
if still nothing happens follow the steps from the
document below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
hope this should work for you or else plz call HP they will replace the printer for you ......................................god bless you (HAMID)
Oct 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
My HP L7680 has stopped printing black. The black cartridge is OK but I have replaced it with a new one to be sure. There is no error message but it just prints all other colours but not black?? HP...
Dear Its,
4 tray cartridge printer, i request you to please by orginal black cartridge ( No.18) and insert into the tray, def. it will start printing ...also if any damge from any relay or cartridge the printer wont work.
So the problem from cartridge only. pls try new.
Jun 28, 2009 | HP Officejet Pro L7680 All-In-One Printer
Carriage Jam.
Try to remove and reinstall the Ink cartridges. Be sure it's lock in place on the cartridge holder. If you still see the error, the printer could be faulty. Call HP if the printer is still under warranty to replace it.
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
The top feeder gets jammed = seems to be a problem with the blue
Open the lid and clean the rollers with Isopropal Alcohol.
It should also be under warranty!
Jun 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
It says the cartridge is jammed but, it doesnt looked jammed
I had a similar problem with my HP C6180 printer, and HP tech support was useless. I had no paper stuck and did all the steps from HP.com. My carriage jam also came with a grinding sound (it was not able to move all the way to the right). I looked inside and and on the lower right side there was a white pad that was raised (I think this cleans the print heads). After unplugging the printer, I used a screw driver to pushed this pad down and to the back of the printer. It moved back and a black sponge like pad moved up from under the front of the printer. I then closed the lid, and used the HP software to clean and realign the print heads. Everything is working fine now. No guarantees this will work for you, but it saved me from having to get a new printer.
Dec 11, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp officejet pro l7680
To solve this problem, you need to set the mirror image to 'off' under the advanced tab of the printing defaults and under the advanced tab of the printing preferences buttons. We had this problem for some time and since doing the above this has stopped.
Steve
Oct 23, 2008 | HP Officejet Pro L7680 All-In-One Printer
Fax wont work
HI,
here is the document that i want you to follow. On this document, just go gown further and STEP FOUR: OPEN THE TOP COVER AND CLEAR THE JAM.
CLiCK HERE TO GET THE DOCUMENT ==> DOCUMENT
Please let me know the outcome after following the document.
Thank you so much.
adonscott
Jul 16, 2008 | HP Officejet Pro L7680 All-In-One Printer
The scanner wouldn't work on a HP L7680 All In One Printer. I downloaded the newest Hp drivers. The scanner started working, but then I couldn't print from Quickbooks(bookkeeping). I uninstalled the...
Hi ,
go to printers in the control pannel.
click on add a printer
in the wizard click on local printer but un check search for the connected printer, under ports check the usb virtual port on which the printer is connected .. under drivers choose HP as manifacturer and under drivers use DESKJET 550C in case of windows XP or DESKJET 990C in case of vista operating system .. try to print is should print .. issue resolved on near about 100 cases
wishing u good luck
Mar 08, 2008 | HP Officejet Pro L7680 All-In-One Printer
HELP !! L7680 Installation causes resources to go to 1000%
End the files from the Taskmanager to work with the printer. Try to search for the HP Digital Imaging Monitor from C:\Program Files\HP\Digital Imaging.
Double-click on the hpqtra08 file to run the HP Digital Imaging Monitor.
Dec 09, 2007 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
Seeker5211
Seeker5211
