Question about Garden
Yard Boy DX70 ride on mower. Will not start this week although was OK last Sunday. Starter motor engages for quarter turn and then a clicking noise starts. The noise does not come from the area around the starter motor. Any help greatfully received. Thanks Terry.
  • 76 Answers
Hi
Check underneath and see if domthing got caught in the blade .
Posted on Jul 20, 2009
Can anyone help me and tell me the part number for a blade for a dx70 Mtd yardman 8.5cc
Duncan, Blade #, MTD Part No 742-0578, 27.5" should be replacement bade for Yardman DX70. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GENUINE 27 5 Blade for Yardman DX70 MTD Beatle Lawnflite 503G Ride on Mower
YARDMAN DX70 MODEL 310 SINGLE BLADE MOWING DECK FG424 5900
Yard Man 13A 325 402 Operator Manual
May 21, 2016 | Mtd Garden
Bolens riding mower
Hi, just like to ask you to try something. Take out the spark plug or plugs and crank over the engine. This should not be a problem for the battery or starter. If this is ok and the motor turns over. Remove the starter motor and check the cog that engages with the engine flywhell to check it is in good condition. If it is damaged that may be the problem. If that is ok then just check that the battery is of the corect amperage ie the amp hours rating it might be that it is too small. Lastly if all those are ok then you might want to change the oil in the engine to one that is less viscous say 15 40. I personaly have had similar problems and tend to put the battery on charge say 1 hour before I want to use it as I sometimes take it to a friends to do their grass. Very last I put the accelerator at half way turn the engine over and pull out the choke as the motor starts to turn. Hopefully these tips will give you a result.
Steve
Nov 14, 2013 | Garden
Yard king runs but ignition key to starter faulty, need to jump directly to starter
check the safety switch on the brake/clutch pedal bypass it with a paper clip to test it
May 09, 2012 | Garden
I have a 2001 yard machine riding mower that cuts off when it gets warm and has no electric
Symptoms would lead me to the coil. They get hot, and die. If it doesn't re-start hot but will after cooling down then its a 99% coil issue
Also after it shuts down and u turn the key to try to start it back up is the starter engaging and trying to spin the motor or are you getting nothing.
If the starter isn't doing anything it could be the starter or relay between ignition switch and starter.
If the starter is engaging and the motor is trying to turn over it could a weak starter or it could be a build up of compression not letting the starter spin it over that a valve adjustment would help. The temp change from cold to hot is sometimes enough make the valves expand and not open enough to release compression for start up.
May 29, 2011 | Mtd 22" Yard Machine Push Mower
I have a countex k15 ride on mower that will not start. Battery fully charged. The starter goes up but seems to get stuck and just a clonking noise??
The clonking noise I assume is the starter drive (bendix) engaging the flywheel. Could be the starter, or a bad connection on your cables from the battery to the solonoid and then to the starter. Check your ground connections from the negative side of the battery to the motor ground also. Clean all connections throughly. IF you have a tester, check the voltage to the starter terminal when it is engaged. It should be close to 12V , if it's low then work on those connections. If none of that works, make sure your motor is free to turn. Try and turn the motor pully, if you can't turn by had, then carefully try to turn slightly with channel locks. If the motor is locked up the starter can't turn it. If all that doesnt work, then the starter could be bad.
Jul 12, 2010 | Briggs & Stratton Garden
Yard Machines RL 638, '07 model, will not start
Sounds like the blades may be engaged. The cable may not have disengaged completely the last time. When the engine is trying to turn over, the belt is engaged trying to turn the blades which could be why the deck is jerking. It will not start if the blades are engaged because of the safety switches.
Apr 30, 2010 | Yard Machines 155 Torque Briggs Stratton...
Riding mower won't start
Check the starter. Sound like the gear on the starter is stuck or broken off and not engaging flywheel.. Just your starter is spinning
Jun 16, 2009 | Mtd Garden
Electric Start Spns & won't engage
i have a riding mower and i get that problem sometimes and what i do to fix it is i take a metal pole and put against the motor and gear on the starter and push when it moves i turn the key and that normally fixes it.
Jun 14, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Starter motor won't activate
Had the mower blades engaged and there must have been a safety switch engaged.
Apr 18, 2009 | Garden
Garden Logo
293 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
