Question about Olympus FE-115 Digital Camera
I have an Olympus camera FE- 115.I went to install the software and it says to install Quicktime 6.4,but I already have Quicktime 7 on my laptop with Windows 10 and I use Google chrome.
SOURCE:
neta
  • 852 Answers
SOURCE: My C3030 digital Camera won't work w/Windows XP
The C3000(which I have) and C3030 are not directly supported by any version of Windows. You must either use the Camedia software to access the camera(via USB connection) or use an external Smartmedia card reader like a ZIO(I have one, it works great). Camedia 2.0 will work(with XP) but it will not allow you to select more than one picture at a time to download from the camera. I have heard that Camedia 2.5 fixes this problem with XP and it is available for purchase from the Olympus website. I decided to get the card reader instead of the new version of Camedia because I use Photoshop to do my editing. I believe only the latest Oly cameras(like the 3020) have direct support under XP. By this I mean when you connect the camera to the PC it shows up as a new drive letter. Hope this helps.
Posted on Sep 11, 2005
Soulvisitor
  • 1113 Answers
SOURCE: FE-280 Olympus
u did see this after pic below, and you have tried deleted usb controllers in device manager then reboot c5374dd.jpg can u tell me if, cam lights up/does windows make a connection sound, when usb from cam is connected? posted by Jordiane on Nov 18, 2007 Report abuse
It says it is unable to find a camera connected to the USB ports. Any idea where I could find a driver to help this or is it another problem?
Have the same problem? Click Here
6 Other Users Have The Same Problem Comment by Emilie, posted on Nov 21, 2007 The display doesn't turn on when the camera is turned on unless I switch the mode on the dial. The camera turns off when I toggle the zoom.
Comment by Guest, posted on Nov 29, 2007 Zoom does not work
Comment by Guest, posted on Dec 27, 2007 I receive the message the software was unable to find an Olympus digital camera conected to a USB port on your computer.
Comment by petedrum, posted on Dec 23, 2007 Same Problem. Tried it on two XP computers, can't find camera on either. Camera lights up when plugged in.
Comment by Kellib, posted on Jan 01, 2008 I'm having the exact same problem with my camera. i can't figure anything out with it and if i plug the usb into the computer, i hit ok for PC and then my computer freezes. someone please please help me figure this out
noavatar_s.png Mickoolz
Rank:nonexpert_s.gif Apprentice
Rating: 70%, 3 votes
I had this same problem, I'm using Vista on my HP laptop and I managed to correct it. Apparently HP like to customize Vista and when connecting some USB device's they don't recognise them as what they should. A USB mass storage device. You will need to connect the camera to the computer, the camera will come on then click the ok button so it selects PC. Wait until it finishes its search click cancel and open device manager, scroll down and below Network Adaptors you should see an expandable tree with an yellow exclamation mark named Portable Device's --> FE-280/X820/C520 you will need to right click on the FE-280/X820/C520 icon and select "Update driver software". Then select "Browse my computer for driver software" then select "Let me pick from a list of device driver's on my computer" Scroll down till you see "Universal serial bus controllers" then select "USB Mass storage device" in the next window. It should all work fine now! If it still doesn't work try selecting "Portable devices" then select "WPD File system device" --> "Microsoft WPD filesystem Volume Driver".
Hope it helps.
Cheers, Mick
Was this solution helpful? Show your Appreciation by rating it:
Posted on Jan 04, 2008
SOURCE: "Write Protect" on Olympus FE-115
I have got an OLYMPUS FE-100 camera, I downloaded the photos in to the computer thereafter the camera has been displaying the “WRITE PROTECTED”message on screen, not allowing me to take new photos and edit the existing ones. It does not have any memory card. I haven’t inserted any memory card yet, it has only internal memory of camera. Could you suggest me the solution
Thanks
Ajay Karthikeya
Posted on Sep 26, 2008
pishta68
  • 594 Answers
SOURCE: can't find serial number for digital camera
The serial number is on the installation disk or the envelope the CD came in, not the camera.
Posted on Dec 01, 2008
Obertelli
  • 3006 Answers
SOURCE: Windows 7 driver for an olympus FE-210
Currently, you can't.
Olympus have not yet released a Windows 7 driver and given that it is an ultra low cost model I doubt that they'll be in any rush to do so.
All you can do is to try and find a Windows 7 compatible xD card reader, but given that xD is now an obsolete format that might also prove to be difficult.
The only remaining option will be to install your current driver onto Win7 and try to run it in compatibility mode.
Sorry there's no straightforward/guaranteed fix here, but these issues always arise with an upgrade to a brand new O.S. version and it often takes up to a year to find out which products will be supported on the new O.S. and which ones will be consigned to obselescence.
Posted on Mar 02, 2010
Problem with the Olympus FE-115 Digital Camera my
Unfortunately, the picture error message means that the image been modified such that the camera can't read it. It is possible that the camera thinks the picture was taken by another camera. Since the picture is still good when you check it with the computer, it hasn't been damaged. Archive the picture and make sure to back it up after it goes on the computer. (If the computer couldn't view it, then you'd need some sort of file recovery software and might not get the entire image back.)
Manuals for the FE-115 are available from the Olympus site: http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?id=1227&fl=8 .
I hope this helps.
Mar 10, 2011 | Olympus FE-115 Digital Camera
My computer went down and i have no software to download my pictures.olympus fe-115
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Feb 16, 2011 | Olympus FE-115 Digital Camera
How to download photos onto computer from Olympus FE-115
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use the supplied software, or any other photo cataloging program.
Jul 09, 2010 | Olympus FE-115 Digital Camera
Driver
Use a card reader instead of your camera.
Feb 03, 2010 | Olympus FE-230 Digital Camera
Two buttons flash and nothing comes up; screen is blank
The problem you are describing is a problem with battery connectivity in the camera. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $51 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 20, 2009 | Olympus FE-115 Digital Camera
I need to download software for a Olympus FE-115.
I need to download software for my FE-210. can you help
Mar 15, 2009 | Olympus Cameras
Need olympus master for FE-115
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
(http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version).
That sounds as if it may be a repair issue with the chip inside the camera that controls image processing. You may want to call Olympus Customer Service to discuss repair policy. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 11, 2009 | Olympus FE-115 Digital Camera
Can't find serial number for digital camera
Dec 01, 2008 | Olympus FE-190 Digital Camera
Check the manual to discover how write protect is achieved with your particular camera/card Some card rely on a silver foil stick[Smart Media] other have a switch. Compact flash rely on a control on the camera. So you will have to have a good browse through the manual - do not forget that there is a Full manual in PDF on the software disk.
Aug 20, 2007 | Olympus FE-115 Digital Camera
Screen is blank
You tell me that you tried new batteries. Have you tried a set of NiMH batteries? They are the best for digital cameras. Please try a set, preferably ones rated 2200 or higher. If this doesn't help, the lens could be jammed. Hang onto the batteries though, because they are rechargeable and can be used in anything that takes AA batteries.
Apr 14, 2007 | Olympus FE-115 Digital Camera
Olympus FE-115 Digital Camera Logo
47 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
