Question about DCS (WOTD-227) Double Oven
Cannot get the oven blub out of dcs oven, the lens cover will not come loose
  • DCS Master
  • 3,463 Answers
Hi.Try spraying WD40 around lens cover.
Then place cloth around lens cover, and grip with a pair of grips, and twist anti-clockwise, it should come off.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
Were do i get parts for model fsco covection oven??????????
where are you located?
I have a DCS-FSCO commercial convection oven, how can I help?
Jun 23, 2014 | DCS FSCO-1 Gas Single Oven
No heat in either oven
DCS by Fisher & Paykel
5900 Skylab Road
Huntington Beach, CA 92647 spacer.gif contact_general.gif spacer.gif 888.936.7872
949.790.8900 spacer.gif contact_tech_support.gif spacer.gif 888.936.7872 spacer.gif contact_service_parts.gif spacer.gif 888.936.7872 spacer.gif spacer.gif contact_tech_questions.gif techsupport@dcsappliances.com spacer.gif
Jan 13, 2008 | DCS (WOTD-227) Double Oven
DCS WOS-130 oven won't turn off. I've turned the breaker off and back on but each time the oven starts heating without turning it on through the controls.
This sounds like a stuck relay on the control board or in rare cases a short to ground in the oven element itself. Test the oven element terminals to the case. If there is continuity then replace the element. If it checks Ok then more than likely there is a welded relay on the board. you can try tapping the relays on the board. Sometimes this jars the contacts loose and things work again. Be prepared to replace the control if this is the case.
Feb 12, 2014 | DCS WO-130 Stainless Steel Electric Single...
Where can I find part no 211696 for dcs oven?
what is this part called and where did you get the part number,then i will help.
Oct 12, 2012 | DCS (WOTD-227) Double Oven
Replacing the blub on Electric Cooker
Was the cover held on with a wire over the center? If so, you should be able to wiggle it back and forth and get it off. You can try spraying a little Pam Veggy Oil around the edge but cover the lens so you don't make it all slippery! If the lens is held on with screws and a metal ring, make sure you removed the screws and ring and do the same thing with the Pam. Afterwards wipe all the Pam residue off before re-assembly.
Aug 09, 2009 | Ovens
F7 error message in DCS 27in double electric oven
hello. here is the customer service department info at DCS. Since this unis is new, Irecommend that you work directly with them so as to avoid voiding the warranty
http://www.dcsranges.com/contact.html
Jun 22, 2009 | DCS (WOTD-227) Double Oven
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
Oct 03, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
Jul 17, 2008 | DCS WO-130 Stainless Steel Electric Single...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
DCS (WOTD-227) Double Oven Logo
163 people viewed this question
Top DCS Ovens Experts
ashburton
Joyce Nokleby
ray gallant
Are you a DCS Oven Expert? Answer questions, earn points and help others
