Question about Maytag MGR6772 Gemini Gas Kitchen Range
Oven not working Maytag MGR6875ADS
Hit buttons for ovens and nothing happens....burners and clock work though!!!
  • 441 Answers
IF THE RANGE IS DOING EVERTHING BUT HEATING THE OVEN IT IS MOST OFTEN THE IGNITOR
Posted on Jul 19, 2009
  • Sean Graham Oct 27, 2011
    if your hitting buttons and te display is not responding be sure your not in sabbath mode if so, refer to your owner's manual and it will tell you how to get out of it. and be careful whern you are cleanning that display. make sure you don't use any ammonia based cleaners. the display will soak up the ammonia base and cause shorts in the circuit, causing you to have to replace the display board.
Maytag precision touch control 500
Either both bake and broil elements are burnt out (highly unlikely) or your control / clock may be bad. Also check to be sure you have 220v going to unit.
Oct 02, 2017 | Ovens
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Nothing heats up on my maytag glasstop but the digital display
an electric range needs 220 volts for top burners and oven to work,if getting only 110 volt the display or clock will work.the most common problem i've found with your curcumstances is a burn't wire where the cord attaches to the range or if hard wired still the same place.pull out your range and inspect all wiring where range connects to house and where house connects to range.if ok take a volt meter and meaurse voltage there at cord area .if not 220 volt reading problem will be with the house.if yes 220 volts will need to trace out the range .then the problem at a place the cook top burners and the oven have in common,wire path wise.
Jan 22, 2009 | Maytag MER5775Q Electric Kitchen Range
Loss of power
There would not be a reset button, but a hard reset can be done by unplugging it for a minute or so, then plugging it back in.
If that doesn't work, chances are you have a fuse blown in the microwave.
It's usually behind the grille, which is held in place by two screws.
Let us know what you find.
Oct 18, 2008 | Maytag MMV5207A Microwave Oven
Oven not working
check its fuses, might be one of them has blown/ open.
Jul 30, 2008 | GE JBP71 Electric Kitchen Range
I was baking in my Maytag range when there was a loud popping noise and the oven stopped working. The broiler, clock and timer do not work either. The control panel will do nothing. The burners work and...
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Jul 11, 2008 | Maytag Kitchen Ranges
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
584 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
