Question about Philips GoGear SA3125/37 MP3 Player
When plugged into the computer, the mp3 player goes off and on, off and on, repeatedly.
  • 17 Answers
Ussually these type of probs are really common. sometimes its becos its synchonyzing itself for the files. or its in charging mode. or the adapter itself needs to be placed properly in order not to move.
Posted on Jul 19, 2009
3 Suggested Answers
SOURCE: MP3 won't turn on. When it does, It turns itself off and won't come back on unless reset. Then problem repeats.
i tried that ..still no use =(
Posted on Nov 08, 2008
nicoleFIXIT
  • 154 Answers
SOURCE: computer not picking up the MP3 player
Some of mp3 player when we plug in to computer it requires the driver. But mostly is not so when you encountered your mp3 not recognized by the computer, try to use another USB cable. We don't know if the cable are bad or good, sometimes USB cable work fine and sometimes not. So use another cable.
Regards
nicole
Posted on Oct 03, 2009
My nextar digital mp3 player shows a computer and mp3 sleeping when i plug it into the computer. How do i fix it? Please help
When mp3 connected with the computer it goes off because that will be acted as usb only and the other funcion will be disabled. Therefore don't worry.
Mar 06, 2013 | Nextar MA933A MP3 Player
On the intro screen it freezez and eventually goes to the next screen and says refreshing database but it dosent refresh
This seems to happen when the database gets corrupted.
1. Turn off the player.
2. Plug the usb cable to the computer, don't plug it to the player.
3. Slide the lock switch to the right, you will see an orange strip.
4. Hold the menu button to start the player. Don't release it yet. Wait until a shutdown message appears and the player goes off again.
5. Plug the usb cable to the player end. The player should go on again. The player should mount as a disk on your computer. Find this disk and back up its contents.
6. Format the player, as explained elsewhere.
7. Disconnect the usb cable. This time the database should refresh properly. Once this is done, slide the the lock switch to the left and turn off the player.
8. Turn the player back on. It should work, but you will have to load your stuff again.
9. Redo steps 1 to 5, except that now should copy your music, videos, etc, back into the player.
10. Repeat step 7.
11. Turn the player back on. It should work again.
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
I connect my sansa e250 into my computer and the mp3 player says connected but i see no sansa hardrive and the computer doesnt respond .
Turn Sansa off. Unplug USB and make sure its clean. Plug back in as normal. If no hardrive comes up go to My Computer and look for it and troubleshoot if necessary.
Finally, repeat this action above accept when you turn MP3 off, hold button for 15 seconds - release and then turn back on.
Nov 05, 2009 | SanDisk Sansa e250 MP3 Player
Computer not picking up the MP3 player
Regards
nicole
Oct 03, 2009 | Audio Players & Recorders
Mach speed trio clip problem
the sound on the mp3 doesnt' work the way it's sopposed to the whole song doesn't play normally
May 20, 2008 | Mach Speed Trio Portable MP3 Player
Won't turn on!!
I had a similar problem. Holding the play button does not work to start it, but pressing it repeatedly and quickly turns it on. Might be the same for you?
Mar 29, 2008 | RCA OPAL M4001 MP3 Player
Will not turn on
Check the batteries, when you plug in to computer, does it comes on and stay?
Sep 01, 2007 | iLO (2 GB) MP3 Player
INOVIX IMP-1112 MP3 crashing my computer.
sounds like bad news - if the flash (update to firmware) failed during update, the item is more than likely dead. Warranty return possible? Can you try another usb device on that same pc? just to verify the usb ports are working properly and supplying proper power to the devices.
Aug 26, 2007 | Inovix iMP-20 MP3 Player
Philips GoGear SA3125/37 MP3 Player Logo
150 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
