Question about Cooktops
I recieved a jenn-air cook top oven with no hook up manual is there anywhere i can find it???
  • 441 Answers
Just go to http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US and enter in the model #, you will get the install specs and customer manuel
Posted on Jul 19, 2009
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 25, 2010 | Jenn-Air JED8430 Electric Cooktop
Jenn Air ElectrCook top One of the cook top heater is not working
well it can only be a few things on a cooktop... u either have a bad element or a bad switch.......usually on most to replace either u must lift top up and out and remove the screws all the way round to open unit up...hope this helps let me know how it goes
Feb 26, 2010 | Cooktops
Do i caulk around my jenn air cooktop?
hello I assume you mean you are installing a new cook top, You can use caulk but its not easy to clean up after. Normally when I install a new cook top I use plumbers putty to seal it and bed it in. Hope this helps! Mike
Oct 27, 2009 | Jenn-Air JED8430 Electric Cooktop
How to start the self-cleaning cycle in jenn-air sce30600?
An electric cooktop uses a great deal more electrical energy than a gas cooktop. The electric portion of the gas cooktop runs the electronics (clock, timer, ignitor, oven light, etc.), and these are small electrical loads. An electric cooktop uses more electrical energy cooking a batch of, say, pasta sauce, than a gas cooktop would normally use in a month or two. There just isn't a good comparison as there is such a broad difference in the electrical usage of the two units.
Sep 20, 2009 | Cooktops
Installing Jenn-Air cooktop, model jed8430
Hi, W/D here.
The plenum is the box the blower assembly attaches to. The blower pulls the cooking vapors down the plenum (well) and discharges through the duct.
Best regards, W/D
Aug 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn Air Not Exhausting During Grilling
is this down draft cook top or give me the m# thanks
Jan 13, 2008 | Jenn-Air JED8230 Electric Cooktop
Cooktops Logo
70 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
