Question about Whirlpool Dryers
We have an LGR4634JQ0 gas dryer. The dryer won't
We have an LGR4634JQ0 gas dryer. The dryer won't heat and the timed dry does advance but the more dry does not. It looks like the igniter starts to glow but then goes out. The vent was a little clogged and we cleaned everything out but it still does not work. Please help.
  • Whirlpool Master
  • 1,606 Answers
Sounds like the coils (both come in 1 pkg ) at least 1 is open . The ignitor glows causing the radiant sensor to open which in turn opens the solenoids which lets the burner lite . OR a BIG OR the thermal fuse (slim white piece with 2 wires attached ) could be bad , This piece is on the blower box . This is probably your problem . Pt # 3392519
Posted on Jul 19, 2009
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2013 | Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Our Whirlpool Model LGR4634JQ0 will not heat up. I took the peep hole cover off and watched as I turned the gas dryer on (high heat). The chamber heats up and glows bright orange for maybe 15-20 seconds...
You're a good detective! Gas dryers have an ignition panel (what you saw glowing bright orange) that heats until it reaches a certain temperature. This temperature will cause the gas from the pilot to ignite and the dryer will run, staying at a constant temperature and thereby drying your clothes. It sounds as it your ignition panel needs to be replaced. It is a relatively simple process if you are comfortable making repairs. If you aren't, I suggest calling a repair professional. We did this a num ber of years ago. The repair service was reasonably priced and our dryer worked for another 6 years!
Good luck. If this works, please return to Fixya and rate my advice!
Jul 31, 2011 | Whirlpool LGR4634J Gas Dryer
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | Dryers
Lgr4634jq0 Takes too long to dry
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back and let me know. I hope you find this information helpful.
Sep 17, 2010 | Whirlpool Dryers
Maytag neptune time dry barely working, sensor dry not working at all
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat during either drying cycle automatic
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Oct 02, 2007 | Dryers
Dryers Logo
214 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
